Question about Vizio GV42L 42 in. LCD Television
My HD picture was fine and a decent fit on the 42" screen and said something like "partial zoom" on the screen when first turned on. My power went off with the set on and now I have "grey bar" and the only two things that fit the screen are stretch and zoom 2 which look bad, cutting off the tops of heads etc etc. DishNetwork is my HD provider. What do I do to return my set to the picture I had before the power outage?
    Genius:
  • 1,043 Answers
Some channels do not display an HD signal 100% of the time. Older shows and certain commercials may not have been shot using HD equipment. You may therefore either have a black border all of the way around your image, or you may find you have to change the Zoom setting before the image looks proper to your eyes.\
On the other hand, if the TV is on the same channel you were watching before your power outage and you are no longer able to adjust the image the way you did before the outage, then something inside the TV was damaged by the power outage. Quite often, just before a power outage your electronic equipment may suffer a power spike. This can damage many of the electronic components inside the TV. It would be impossible to identify which part or parts have been damaged without being able to take some measurements.
Before you have a repair tech take a look at your set you can try and reset all of your setting back to factory default to see if that will also reset your issue. Bring up your TV's menu and highlight the icon that looks like a gear.Then move your cursor to the last choice on that screen that is tiled "Reset All Settings", and then press the right arrow button. This will reset all of your display setting back to the level they were set at the factory. If that doesn't fix the zoom issue you can also try and unplug the TV and leave it that way for 1/2 hour. That may also reset the picture back to normal. If none of these attempts gives you back the picture you had previous to the outage then you definitely have a part or parts that were damaged.
Posted on May 08, 2010
How do I return to a ``Normal`` HD screen from ``Partial Zoom``? Bill
Look for a button on the remote said like ASPECT RATIO,VIEWMODES.PICTURES.Pushes one of these bottons pick the picture that fit ur tv screen.
Jan 15, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Gray bars on side of picture
Yes. There are options. Strech, wide, full, zoom, and gray bar are common options. Some times when aa HD channel is not broadcasting in HD you will also get a narrow picture.
Apr 30, 2010 | LG 42LG50 42 in. LCD HDTV
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Feb 24, 2010 | Samsung LN55B650 55 in. LCD HDTV
Screen only partial and only shows in red and black
sir/mam the problem of your plasma t.v is the panel,weak panel. i have already encountered that kind of problem.
Aug 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
The picture on my tv went small
Go into your picture set up menu, which should be in the main menu for the TV, and change your aspect ratio.
Jun 13, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
64 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
