Question about Car Audio & Video
Need the parking brake bypass code to for power acoustics ptid-7350n
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The parking brake wire has to connect to ground when the switch is in one position and connect to nothing when the switch is in the other position. You may also disconnect the positive wire from the switch. If not, leave the positive wire off and try the remaining two wires, ground wire and parking brake wire, on different prongs of the switch. Connect the ground wire and the parking brake to get pictures.
If still the issue is not resolved, then bypass the parking brake function in the menu and do not connect that wire. Follow the step-by-step parking brake bypass procedure---
First please select AM/FM mode and press "setup" on the remote control. Now enter 543210 on the remote. Note the beep for each entered numbers. New menu will appear. Now press hammer/screwdriver button and select brake bypass to "on" and hit the "x" near the bottom of the screen.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 08, 2010
Need a code to by pass parking brake feature
usually not a code. it is unlawful to drive without the parking brake feature hooked up.... but the way to do it is remove the wire from the parking brake and ground it. it will then think the parking brake is on
Feb 09, 2011 | Power Acoustik PTID-8300NR Car Video...
How do i get the blue parking brake screen off so i can whatch a dvd
Take the parking brake wire from the deck and hook it to a toggle switch on the end of that switch run a switch to a ground. When powering up toggle the switch on and off and your in business
Jul 31, 2010 | Power Acoustik PTID-5300 Car DVD Player
Bypass having to use the parking brake on power acoustik ptid7250
no, you can't, because watching a video while you drive is an insanely stupid thing to do.
Feb 03, 2010 | Power Acoustik PTID-7250N Car DVD Player
I bypassed the parking brake and the dvd works but when i put the car in drive the remote wire for my amp turns off any ideals why? what can i do to fix this.
what i did is i got a 4 prong relay. its gonna have numbers on it for certain wires. the 86 is for your remote wire and the 85 is for the parking brake wire. the other 2 are just grounds.this worked on mine so it should work for yours.
May 16, 2009 | Power Acoustik PTID-4003TV Car Video...
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
Mar 03, 2008 | Power Acoustik PTID-4005 Car Video Player
PTID-5800
Yes you can...i have seen this done.
Get a switch from walmart with 3 plugs to it, 1 for power, 1 for acc, and 1 for ground. Splice the ground and battery cords and attatch them accordingly to the switch. The back cable...i think its pink or orange attach to the accessories....should be the one in the middle on the switch... WHen the switch is off then you can watch while you drive...hope i helped
Jan 05, 2008 | Power Acoustik PTID-4003TV Car Video...
Cannot see video
What i did was get a switch from walmart. they cost less than 2 bucks...Get one that has 3 slots..1 for power, 1 for acc, 1 for ground. Plug the brake cord the acc, and splice the power and ground cords to the other two. When your switch is off you can watch video while you drive, when its on it will cut the video off and display that message.....
If you want to do it the right way, then plug it into the emergency brake line or the parking brake line...hope i helped
Dec 09, 2007 | Power Acoustik PTID-4003TV Car Video...
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
