Question about Power Acoustik PTID-7350N Car DVD Player
Need parking brake bypass code to watch dvd - Power Acoustik PTID-7350N Car DVD Player
  • wpbrascal May 08, 2010
    how to bypass power acoustics ptid-7359n? need code
    need bypass code to watch dvd on a power acoustics ptid-7350n.
  • 493 Answers
That is a safety feature to keep you and others safe. And not recommended by me. But I read somewhere that if you connect the parking brake wire from the device to the ground it may work.
Hope this helps.
Posted on May 08, 2010
    Genius:
  • 1,040 Answers
Dear Wpbrascal,
This is what you do. You need a toggle switch a simple on and off switch. Connect your ebrake wire to the toggle switch and then a wire that is grounded to the toggle switch. Turn on your dvd player and when the warning message appears turn your toggle switch on and off and on and then you will be able to watch your movie.
You need a toggle switch something that looks like thisneed parking brake bypass code - 14e586e.jpg Connect your E brake wire to the left or right side of the toggle switch where the screws are. The E brake wire should be a white and blue colored wire and should be labeled already. Next you need to connect a ground to your toggle switch. The ground is usually a black wire. Connect that wire to your toggle switch. The ground that I used for my toggle switch is the same ground for the stereo I used. I just spliced into that. After that is all complete. Put your toggle switch some where in your vehicle where it can not be viewed easily. Insert a dvd into your head unit. Then when the blue screen appears saying you need to be in park to watch a movie use your toggle switch on off on off on. and you should be able to watch movies.
PS: To test it before you hook up your toggle switch touch your ebrake wire to a ground wire and then remove it then touch it again and hold it there and that should engage your movie. Use that method to ensure you have a good ground.
  • Yogesh Kshatriya May 08, 2010
    OR YOU CAN TRY THIS..........
    These methods have worked on a variety of DVD systems.
    OPTION NO.1.......
    1. FACTORY RESET METHOD (Temporary)
    (This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
    ** Go to the Menu
    ** Get to the Settings Menu
    ** Select to Reset to Factory Settings.
    OPTION NO.2...
    DVD METHOD (Permanent)
    ** Insert a DVD
    ** Let it play until you hear sound
    ** Press STOP twice on remote
    ** Enter 26604
    ** Press ENTER
  • 668 Answers
The code will be in product id card . Reset the unit by disconnecting the battery . Now connect the battery and now it will ask for the code ,just enter the code in product id card .
Hope this helps .
How to bypass the parking brake on a nesa DVD deck
what i did was put the pink cable(parking brake) and connect it to ground(black) of the stereo harness and then both of them hook it up to the black cable of the car which is ground or negative.
Jun 11, 2010 | Jensen's VM9312 Car DVD Player
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
BYPASS
The security device was created to avoid you from watching DVD's while driving. It is simple to bypass. Simply take the parking brake wire (blue/yellow stripe wire) and connect it to the a ground wire (all black wire). This will trick the DVD player into thinking that the car is in park with the parking brake on at all times.
Apr 03, 2008 | Panasonic CQ-VD7001U Car DVD Player
Parking Brake Bypass
I know my PLTS75 when we hooked it up. you connect the brake wire to the negative pole to bypass that
Mar 28, 2008 | Pyle PLDF7IN Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Bypass code
What you need is a video bypass module and you can get it at ebay.com
The module number is TR-7
Jan 26, 2008 | Car Audio & Video
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Power Acoustik PTID-7350N Car DVD Player Logo
99 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
