Lanier LD235 printer
Can't see my scanned in copies, can't select download the option is not their also won't scan the documents, no errors occure.
5 Suggested Answers
mrbench87
  • 40 Answers
SOURCE: scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Posted on Aug 31, 2008
rakeshpramod
  • 234 Answers
SOURCE: No Scan Options for HP Oficejet 6310
This is a resolution for "NO SCAN OPTIONS" in the front panel screen of the All-In-One Only:
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution (if not got to Start> All Programs> HP> HP Solution Center) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Posted on Sep 11, 2008
SOURCE: scanning multiple copies
The trick is to put the scanner in PROFESSIONAL MODE !!!!! Select that option in the top right corner of the Epson Scan application when it first opens up.
http://files.support.epson.com/htmldocs/gt25__/gt25__ug/projs_1.htm
Posted on Dec 10, 2008
antiochpc
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
  • 19 Answers
SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Posted on Jun 18, 2009
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
Can the SP 204 SF scan to pdf?
Here's a workaround while you're searching.
Download CutePDF or PDF redirect and install.
Now after you scan to picture, copy and paste to a document and print or just print the image and send to the new 'printer' to PDF thingee and voila ...
PDF reDirect The free PDF Creator alternative to pdf995 cutepdf and freepdf
Feb 10, 2015 | Lanier Office Equipment & Supplies
How to reset fuser error code on lanier ld235?
Come into test mode, if it comes back the fuser service needed. -Carl
Oct 06, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Sep 11, 2014 | Lanier Ld 430c With Feed, Bank, Print,...
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
I cant seem to find a scan option on my epson
Once all of the drivers are downloaded and the printer is connected to your computer, you can initiate a scan of a document two ways.
First, you can select Copy on the printer and it will copy the document placed on the scanner.
Second, you can scan a document to your computer by going to: Start > All Programs > Accessories > Paint.
When the Paint program opens, (in the upper toolbar) click: 'File' and scroll to 'From Scanner or Camera'. Then, select your device (Epson scanner) and click, 'OK'.
Continue with the prompts and your scan will be imported into the Paint Program. To save your scan, Click, File > Save As > (name your document) and select a folder for your scan to be sent to.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Feb 03, 2010 | Epson Office Equipment & Supplies
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
Can't Scan documents
on the scan options , "select "scan to pdf", it will scan as a document instead of printing.
May 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
91 people viewed this question
