Question about Frigidaire GLTR1670A Front Load Washer
Water smells on discharge - Frigidaire GLTR1670A Front Load Washer
  • Frigidaire Expert
  • 414 Answers
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Posted on Jul 06, 2010
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
The water from the discharge hose smells extremely bad. How do I stop this smell
There is a solution that you run through the machine, routinely, that helps this issue. Many of the machines do that smell thing.
Jan 30, 2011 | Samsung Washing Machines
There is a terrible smell from my washer
Hi, what happens is that water sits at the bottom of the discharge pipe, as well as a build up of "gunk", which is a great breeding ground for bacteria and such. So during the first rinse out, the smelly water and gunk is discharged into the drain, and the smell comes up from the laundry tub drain. Pour a few cups of bleach into the discharge hose and let it sit for an hour. This will kill all the nasties. Then just run the machine once through to pump out the bleach.
Sep 09, 2010 | KitchenAid KHWS01PMT Front Load Washer
My washington machine water smells horrible, but not the water in the rest of the house. It all enters the house through the same pipe from the municipal water supply. Could there be something within the...
You probally have a front load washing machine. There is probally mildew in the wash tub & discharge hoses. Try washing an empty load with a hot water and a cup of vineagar and see if that helps with the odor. If it does, then repeat this once a month.
Jul 20, 2010 | Maytag Washing Machines
I have Dishwasher FDB520RHBO and it smells like rotten milk/eggs each time we wash dishes. The filter is clean and it is less then one year old. What could be wrong?
Check your main drain system, where you discharge the water.
Remove the machine hose and collect the washed water in a bucket. Check the m/c for smelling. No mell noticed then check the main drain.
Apr 16, 2010 | Dishwashers
Washing machine wont discharge water
washer does not completely discharge water, clothes smell like wet dog.
Jul 05, 2009 | Washing Machines
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
Stegnant water smell
It should completely empty the m/c.
If it is plumbed into your sink waste this could be cause of smell, also if it is connected to your waste make sure the hose is above the bottom of the sink trap,as water can sometimes syphon back into the washer from the sink. Remove hose from sink connection and clean and check for obstruction.
I doubt your pump is faulty.
If it goes into a stand pipe make sure this is not partially blocked, and again clean stand pipe with a strong disinfectant or similar
Plz rate my solution.
Thanks.
Dec 21, 2008 | Hotpoint VVSR1070D Top Load Washer
Discharge water smell
I found pouring baking soda down the drain once a month solves this problem...
Oct 20, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Frigidaire GLTR1670A Front Load Washer Logo
82 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
