Question about NEC Dterm DTP 16D-1 Corded Phone
Reconnect phone jack wire
I have a nec phone system the blue wire from the jack came loose how do i reconnect?
  • dolphi1252 Feb 18, 2009
    I have 4 jacks in my house, two were disconnected for vonage. I no longer have vonage and want to reconnect by phone wires. How do I do this? thank you.
    Problem Solver:
  • 7 Answers
Put the blue wire back on the red wire from the jack.
Posted on Nov 28, 2008
SOURCE:
My acative stays on even unplugged on my bass
when you say on, do you mean the battery continues to drain? If that is the case, check the battery ground wire at the jack...has it been repaired recently? Sometimes techs reconnect it to the main system ground, which continuously drains the battery whether plugged in or not. Or...sometimes the battery ground wire tab on the jack is touching shielding (if it is loose and rotates)...that would cause the same issue...
Sep 24, 2012 | Schecter Music
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
The jack peice will only work if i wiggle the wire around.
Your jack is probably loose, the only solution is to reconnect, or solder it.
May 29, 2010 | Skull Candy Ink'd Stereo Ear Bud...
How to register phones?
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Mar 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
My tru9480 handset is saying connecting but won't connect and won't get a dialtone
Jun 13, 2009 | Uniden TRU9480 Cordless Telephone
Uniden base display does not work after chargin for 1st time.
Question:
What is the general reset procedure for cordless phones?
Answer:
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
Hit the deregistration button. phone will not work now.
Question:
Answer:
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
My phone is dead
Question:
Answer:
7805 model
please rate this post!!
Aug 24, 2008 | Uniden 5.8GHz Dual Cordless Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
114 people viewed this question
Top NEC Lands Phones Experts
Ekse
Norman Al-Anbar
ray gallant
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
