Question about Canon PIXMA iP1500 InkJet Photo Printer
Printer will not print, fine last time i used it switched of the computor, when i wanted to print next time it just will not print, tried test print without sucsess
    Guru:
  • Canon Master
  • 1,705 Answers
You're cartridges have dried out and/or you print head has blocked.
I'd try new cartridges and use the printer toolbox to clean the print head. You printer toolbox would have been installed when you installed you printer. I'd click on Start - All Programmes and look for Canon.
Posted on May 08, 2010
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
When I try to print it is fine until the last
Strangely it actually solved itself overnight!
When I switched on the next morning the problem had gone.
Thank you for your interest.
Joan.
Oct 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I can not connect the printer to the laptop. It is saying that it is not compatible. The last time I used the printer(cannon i550x) it used windows 98 but the new laptop is vista so it is incompatible. can...
Try this procedure for Vista:
  • Go to start
  • Printers
  • Add printer
  • Press next
  • Select local printer
  • Press next
  • Select Canon in the left column
  • Select in the right column your type
  • Press next till you have finish
  • Press finish and try to print a test page
Sep 30, 2009 | Computers & Internet
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Prints blank page my lexmarkx5150 all in one
Okay, I know this may sound silly but make sure the document you are trying to print is not using a White Font. Don't laugh, I've actually see this once before. Next, try a stand alone printer test Disconnect the printer from the PC and using the printers panel go to Maintenance Menu and either print out a test page or a demo document. If that works, then re-connect your printer to the PC and using the printer's driver, print a test page. Last step, make sure that all of the printer setup are the same, especially the Page Set-up from the application. Don
Jun 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
Mar 22, 2009 | Dell 948 All-In-One InkJet Printer
My printer keeps printing the test page every time it's switched on
Unplug the printer and leave it for three minutes and then plug it back in. This will reboot it and it may cure the problem.
Feb 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
Won't print black
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 19, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Test page
Try shutting down your PC and printer. Next,unplug PC from wall outlet. Next, unplug printer USB cable from the PC, then unplug the USB cable from the printer. Unplug the printer from the wall outlet. Wait 30 seconds. Next, plug PC back into outlet, turn it on, and wait until it has completely initialized and is ready to use. Next, plug in the USB cable from the printer to the PC, and turn on the printer. Windows should automatically detect the printer, and will proceed to install it. After the PC finishes the install, test the printer in all modes, including self-cleaning, to see if the problem is eliminated.
Aug 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
0.gif Re: HP PSC 1513 all in one by Bert t.gif (9/25/07 1:07 PM) reply + / - http://h10025.www1.hp.com
0.gif Re: Re: HP PSC 1513 all in one test page always pr by Anonymous (12/12/07 6:14 AM) reply + / - Subject : How to disable the test page that always prints when you switch on the HP PSC 1513 all-in-one printer.
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
Then it will stop printing the test page ( alignment page ) ever again.
This is a really stupid product feature on HP's part to waste ink and force people to buy more cartriges.
beukes2@gmail.com
Nov 29, 2007 | Office Equipment & Supplies
Canon PIXMA iP1500 InkJet Photo Printer Logo
118 people viewed this question
old marine
old marine
