Question about HP Officejet Pro 850 InkJet Printer
Carriage Jam HP 8500 printer/fax/copier. Carriage Jam message, have inspected printer from all angles, cannot see any paper jammed anywhere. Tried turning printer off and on to reset, still have a carriage jam message and will not allow me to print. Rolled the rollers by hand to find any jams, still nothing.... Thanks
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Posted on Sep 28, 2010
  • Rosalie Dieteman
    Rosalie Dieteman Apr 14, 2014
    If it is lack of lubricant on the chrome bar, what should I use?
    Guru:
  • HP Master
  • 1,705 Answers
It may be the print head carriage, its usually a chrome bar which runs across the printer transporting the print head from left to right.
Normally they're greasy, a light, white electrical grease. It may have been rubbed off at one end.
Try opening the cartridge door, does the cartidge move to the middle for extraction, if not try and tease it along. Assuming you've been able to move it, ensure there's no build up of dust or dry patches on the bar.....................Good luck.
Posted on May 08, 2010
  • Rosalie Dieteman
    Correct error message: Cat toy inside printer! It does need ink clean up in there, but removing the cat toy has it up and running!
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
HP officejet printer 8500 is giving erroneous paper jam messages! What's the problem?
>Remove back cover(duplex) check any paper object jammed? remove it.. >remove paper tray observe any paper objects visible? remove it>Check paper path sensor located at the path of carriage assembly.. observe for free play of sensor flag...
Jan 30, 2012 | HP Office Equipment & Supplies
Had paper jam, removed from back of machine, now display says Carriage Jam Open print carriage access door, clear jam and press ok. I have done this and still flashing up the same msg. There isnt...
If the printer thinks it has a Carriage jam, you might want to try removing the ink cartridges and then putting them back. It's possible they got bumped out of place during the paper jam. Hope you can figure it out!
Feb 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Carriage Jam problem. Have gone through complete troubleshooting routine, but the message just won't go away. Says ""Carriage Jam". No debris to left or right of carriage. In fact, the jam was in the paper...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My printer is saying "Carriage Jam" and that I should remove Jam and press okay. I can not see a jam anywhere and have tried everything. Do you have any suggestions?
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things.
Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside.
Also the paper being used should be as per the manufacturer's recommendations.
Turn off the printer when removing bits of paper.
If there is a broken gear, do not repair it yourself. Call an expert technician to mend it. get more help for HP Carriage Jam .
Sep 20, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
My brand new hp 8500 wireless office ink jet printer say open the carriage access door clear the jam. We took the small 2 ink cartiages out and put them in again and this keeps come up.What do we do now?...
Why are you taking out the ink cartridges??
The message says to open the carriage access door and clear the jam. The printer thinks that paper is stuck in the paper path, see if you can find it. I believe that there is also a rear door on that printer, remove it and look inside.
Sep 10, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Error message - carriage jam
Sep 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Pro 8500 printer has carriage jam. I have opened every door and there is no paper jam.
Sometimes the paper gets caught inside the printer all the way to the right (or left) of the print carriage. You will miss seeing it because the print carriage has moved the jamed paper to the right (or left) out of view. Carefully and manually move the print carriage to the opposite side and you might find small pieces of jammed paper there.
Jul 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Oct 11, 2009 | HP Office Equipment & Supplies
HP Officejet Pro 850 InkJet Printer Logo
386 people viewed this question
Seeker5211
Seeker5211
