Question about Graco 9445DOH Crib
Graco fold and play
We can not figure out how to get the rails to lock on the fold and play!
frustrated grandparents
We cannot breakdown our pack and play. How do we get the top rails down?
In order to break down the top of your Graco Pack 'n Play, you must find the middle of the bars. It's easiest to collapse the the shorter ends first. The middle of the bars should have a nodule. Squeeze that nodule and pull up on the side, sometimes you may have to do this firmly and **** the side. When the first side collapses, repeat for all sides. Once they are collapsed, pull up on the bottom of the Pack 'n Play, and it will fold together.
Dec 07, 2010 | Graco Pack 'n Play
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How cani open graco play pen
To open the Graco Pack 'n Play from the folded position, you have to latch each side rail by pushing the two ends of each rail until they are horizontal and form a straight line. They will latch into place with an audible snap -- do this for each of the four sides. Then push the center of the Pack 'n Play's floor down until it is flat as well.
If you can't latch the side rails, the floor of the Pack 'n Play might be down too far. Push the floor up until its center reaches at least halfway up the sides of the Pack 'n Play. (You can do this by pushing the sides of the Pack 'n Play in toward each other.)
Were you able to open it using these instructions?
Jun 24, 2010 | Graco Pack 'n Play
Pack-n-play will not break down when trying to fold it up. the 2 locking arm under the center will not release. Is this fixable?
will rlese if you turn and pull the center of the cot and then pull up till you feel that it's done.
it's treaky and coming back blocked very fast. you have handle all of them at the same time
Good luck.
Meggita
Sep 25, 2009 | Graco Pack 'n Play
How do i get the sides to lock/ stay up on my Graco Pack and Play?
I think the problem is the way that the safety feature prevents the locking mechanism from moving while the bottom is flat Be sure that the bottom is raised about half way and the rails should lock (or unlock) for you. Hope that helps. wdeblancjr@aolcom
Jun 13, 2009 | Graco Pack 'n Play
Need help
Be sure that the bottom is not flat. The rails will not lock (or unlock) with the bottom flat. I great safety feature!
Jun 11, 2009 | Graco Pack 'n Play
Graco 9445DOH Crib Logo
166 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
