SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
SOURCE: Whirlpool 1A-1B Washing Machine door leak
solution fit new door seal,its leaking where door seal meets glass
SOURCE: F-05 error code Hotpoint WT746
I have the same problem too, which I see the water was not able to drain in the last stage. I tried to drain the water manually by turning the button to drainage, then follow it by turning to spin... Result seen is water drained and it spin down and drain the last water out too. I shall wash another round of clothes and check out the final result.
SOURCE: hotpoint ultima wt746 error f-12
Just had F-12 on my Hotpoint Aquarius washing machine. Problem was due to water not draining. Power off. My machine has access plate at bottom on the back. The water drain is held onto the drum via a jubilee clip and when i took it off the drain was clogged with hair, sweet wrappers, money, hair bobbles Once cleared, put back as was - machine now running ok..
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display.
This is apparently a failure to drain properly.
I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains.
Turn off the water supply to the machine.
Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water)
Remove the drain hose from where you have it going to.
Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water).
Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum.
Use some pliers to pinch the steel spring that clamps the hose in place and remove.
Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on.
Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks).
Plug it in, turn on and that for me was it.
Job Done.
