Lennox pulse 21 furnace - nothing runs on but control board tries
I have a lennox pulse 21 furnace. Not sure when it was installed as it came with the house when I bought it. This winter the furnace began failing at random times and resetting the power fixed the problem. I've read some of the other posts here about the furnace but haven't found anything quite like this yet. i changed the main filter and did some basic cleaning etc.
After awhile, the problem became too frequent to ignore so I started to look into things. At first I thought the inducer blower motor was bad because this was the first thing to kick on when the power was turned on to the furnace. If the blower ran, then the furnace ran. If not, then not - but the control board still tried to activate the next thing in line after 15 seconds or so. So I found a new inducer motor pretty cheap and replaced it, and for a week or so it worked okay. But then the next thing in line after the inducer failed to kick on a few times. Now I'm at the point where the control board still 'clicks' as it tries to make things turn on but the inducer won't even work. So I'm thinking it's either a power issue or the control board but not sure where to go with it. I took the cover off of the control board, and found a few of the diodes weren't straight, they had bent over to touch other things and had stuck together a little. But without much electrical skill it's hard to diagnose the condition of the board.
I realize that replacement is recommended alot of times regarding this furnace, and I would love to but money is most definitely an issue right now so if there's a sulotion I can handle myself, I'd like to go that route first.
Thoughts?
    Champion:
  • 233 Answers
You will need to verify voltage from the board to the inducer. If you have the installtion manual there is a flow chart for the sequence of operation of the furnace.
The basic sequence is:
1. thermostat calls for heat
2. inducer motor starts and runs for a pre-set amount of time
3. the pressure switch closes and allows for ignition trial
4. ignition is proved back to the board allowing the system to operate.
Verify 120VAC to the inducer motor upon call for heat from stat, if you have 120 at the leads that connect to the inducer and it does not start , the motor is faulty. If the inducer starts use a voltmeter across the pressure switch terminals, a voltage reading of 0 VAC will verify contact closure and ignition should occur.
The pulse furnace was under a factory recall due to breaches in the heat exchanger, unfortunately for you, the Lennox Corp. has ended the program that allowed for an allowance / furnace for replacement. To test the heat exchanger a special kit is required from lennox that will verify integrity of the heat exchanger. (If the heat exchanger seal has been comrimised the pressure switch will not prove and the igniton sequence will be interupted and cause the system to go into "lock-out" mode).I know this is probably not what you wanted to hear. Hope this helps, please list as "very helpful" if it did
Posted on May 08, 2010
2 Suggested Answers
gear001
  • 59 Answers
SOURCE: I have a Lennox Pulse furnace. It's making a
The bearings are bad. You need to replace the motor. Motor cost $75 to $125. Labor is on avg. $150 to $400 with an decent A/C Company . You can try to oil it but its not recommend by Lennox. That furnace at the time they build it was top of the line. Good Luck.
Posted on Oct 14, 2009
I want to connect a NEST thermostat with WiFi to my Lennox furnace. The existing iComfort by lennox has 4 wires, R, I+, I-, and C. Where would these connect on the Nest?
They don't. And why would you want to trade it out??? You are currently running off the communicating terminals. If you are going to install a nest you will have to match the nest wiring with the legacy/24volt terminals on the furnace control board and likely the outdoor unit will need rewired as well. Not extremely difficult but why??? The nest is not what it's cracked up to be!!
Sep 12, 2017 | Heating & Cooling
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
I have a Lennox Pulse 21 model G21Q4/5-100-3. The blower motor will not turn off even if the thermostat is in the off position. I suspect a stuck relay or control. Any advice?
That can be a bad relay, but it also can be the high limit has tripped...or went bad...when the high limit thinks that the furnace is too hot the blower will run continuously...
The best way to troubleshoot is to unhook a wire from the high limit and see if the blower stops... if it does then the high limit is bad or needs to be reset...
if it continues to run then the relay is likely welded together...
heatman101
Sep 17, 2011 | Heating & Cooling
Have a aprilair 550 for some time. Installed a new Lennox G61MP furnace and the technitions failed to reconnect the wiring that powers the humidifier. Need wiring schematic. Does humidifier transformer get...
Hello, yes the transformer will get a 120 volts from the Furnaces control board, there should be a terminal labeled HUM on the control board. You need to bring 2 wires one from HUM and one from a nuetral tap on the board to the line side of the transformer, this way every time the blower motor on the Furnace turns on the humidifier will aswell.
Aug 23, 2011 | Aprilaire 550 Humidifier
I have Lennox pulse 21 control module light goes out
If this is a high eff model, check to make sure the intake vent is not plugged.
Jan 17, 2010 | Heating & Cooling
No ignition on pulse furnace. runs through cycle trying to start and you can smell gas outside by the exhaust tube
MAYBE the module. If you call for help be sure they know how to work on a Pulse or they're likely to just tell you to replace the furnace (try to find a company that was a Lennox dealer at least 10 years ago). The Pulse is a very different animal that many in my industry don't understand and are quick to fault - the Edsel of the heating industry.
Oct 15, 2009 | Optimus Heating & Cooling
Oct 14, 2009 | Heating & Cooling
Very loud induced draft furnace
when you tighted it it very well could have done damage to the motor or you could have it off kilter 1 of the 2
Feb 04, 2009 | Superior Lennox Blower Thermal Sensor -...
Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
1,658 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
