Question about Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
When turned on it makes a high pitched whine.
My kenmore progressive with direct drive vacuum cleaner makes a high pitched whine when it is on. It still has suction, but not as good as originally. This machine is about 8 years old. It is the purple machine. It doesn't appear to be clogged.
  • 67 Answers
SOURCE: I have a Kenmore Progressive Inteleclean Upright
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Posted on Sep 22, 2009
renevacdoc
  • 84 Answers
SOURCE: Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Posted on Nov 10, 2009
  • 4088 Answers
SOURCE: I have a Kenmore Progressive Upright Vacuum -
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Posted on Dec 24, 2009
SOURCE: Kenmore Progressive vacuum clogs continuosly
Try taking the bottom off and this will reveal if you have something clogging up the flexible tube. Just did this last night there was a ton of junk clogging the tube and I cleaned it all out and put it back together now it works fine. Seems like with the design of the vacuum this will always be a problem.
Posted on Dec 30, 2009
  • 4102 Answers
SOURCE: My vacuum is making a high pitched sound and has
hi, what this points towards is a blockage either in the pipe or where the filters are, if you dont unblock it then it will over heat and blow the motor.
This is a very common fault for this make of vac and they dont tend to last long anyway.
Your best option would be to remove the part you empty and take out any filters you can get access to give the filters a good clean by banging them on a wall to remove any build up of dust and hair.
The have a look at the pipe try and take the pipe off the usual place for blockage is where the pipe goes into the vac so check here for blockage its usually just a build up of stuff you have vac up that has caused a blockage.
as you have no suction from the hose you would then have no suction at the floor part so dont try using it like it is . you need to remove the hose its either screwed in or held in by two plastic clips that you can push with a screwdriver once you have undone this you should be able to see the blockage.
Let me know how you get on or if you need further assistance ok
Posted on Jan 18, 2010
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
High pitched sound when power on
I had a vacuum cleaner that did the same thing. My vacuum had three suction levels. The noise level would decrease as I lowered the level. I also noticed that when I turned the vacuum off the sound didn't stop instantly, it wound down/faded off as the motor slowed down. I found the problem to be the bearings in the main motor. I've been told that the motor that powers the carpet brushes can also make the sound if the motor bearing fails.
Dec 29, 2012 | Kenmore Progressive Bagless Upright with...
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
I have a Premalite vacuum, Model721.37060700 bagless. It is working but has started making a high pitched whining sound, with slight burning odor.
This is the brushes in the motor burning out by time you get this message the cleaner will have stopped. Replace motor or replace machine. Motor can be replaced because that was my last job mending vacuum cleaners. I think Godfreys may repair them or any small electrical store or you can do it yourself.
May 03, 2010 | Vacuums
My vaccuum has no more suction
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Feb 22, 2010 | Kenmore 31913 Progressive Direct Drive...
Vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Jul 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore model 116. 35912401 very very load
This could also be a problem with your direct drive. These machines have a gearbox instead of a belt. (a system they quickly went away from) You may want to first take off the bottom plate and make sure there is nothing in the brushroller compartment as a paperclip can make a machine sound like an aircraft engine if in the right spot.
My best advice would be take it to a vacuum store that does warranty service for panasonic vacuums (they're made by panasonic for sears) They should be able to tell you for free in most cases after listening to it for 30 seconds wether its the motor or the gear drive and how much the parts are.
Best of Luck!
Jun 08, 2009 | Kenmore 31913 Progressive Direct Drive...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum Logo
110 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
