Question about GE Refrigerators
My fridge will not cycle by itself. If I rap the FRESH FOOD SECTION Section control area, it kicks in. What could be the problem?
    President:
  • 1,218 Answers
Good day,
Typical of a thermostat hanging up. Replacing it would be the only solution.
Posted on May 08, 2010
Kenmore bottom freezer 795.78309.804 codes er/ff what do they mean? is food going bad?
Model number 795 it's an LG fridge. Even if it says Kenmore on it. LG is the manufacturer of that fridge. If it's a newer fridge & or your the original owner. Take the kick plate off the bottom front of the fridge. Either in that kick plate or looking in were that kick plate was on the top wall of the bottom of the fridge you'll see a plastic envelope with sone folded up papers in it. Those white pages are called tech sheets for the tech that comes to your house to fix your fridge. They are best left under the fridge or in the kick plate but alot of the time they aren't put back. Why I asked if yiur the original owner. If you are able to locate those tech sheets. They should list the trouble codes and what the code stands for. I don't remember what it stands for. Taking a guess it means error fresh food or er/ff. Don't quote me on it I'm not sure of my answer but I think it's a faulty thermistor in the fresh food section. Fresh food section is the refrigerator section. Please check to make sure you have the correct problem before doing anything. I'm taking a guess just from memory as to what the error code is. At least with the tech sheets, hope they are there. You'll be able to find out what the code means.
Hope that helps you a little or alot. Thanks
Oct 17, 2016 | Kenmore Refrigerators
Our fridge seems to work like a freezer no matter what setting is on, is this a known problem? The model is a Gorenje fridge/freezer model: HZOS 3366
Hello Nick;
My name is Peter. I am a retired field service refrigeration technician.
I assume you are from the United Kingdom based on your unit. I am from Baltimore, Maryland, USA.
Yes, this is a common problem and a simple one to fix. Your only cooling source is from your freezer. There is a vent from your freezer that blows cool air into your fresh food section. This vent is probably motorized and controlled by a temperature sensor in your fresh food section. Either the vent assembly is bad and stuck open or you have a bad fresh food section temperature sensor..
Temp fix: With tape or cotton balls or something locate the air vent to your fresh food section and block at least 1/2 of the air flow vent ports to your fresh food section.
Nov 13, 2014 | Refrigerators
What is the ideal setting for fridge on Bosch KGN34VW20G
Hello John;
My name is Peter. I am a retired Sears service technician. The freezer temperature should be between -2 & + 2 degrees F. The fresh food section should be between 35-40 degree F.
Pick up a inexpensive temperature gauge with a steel shank. Place the temperature gauge in the freezer center. Do not make contact with any food product. Allow 20 minutes and read the gauge. Be quick the temperature on the gauge will drop quickly when you remove. Adjust the temperature control knob according until you reach the desired setting. Repeat this process as necessary. Do the same for the fresh food section.
You only have one source of cooling; the evaporator coil and fan in the freezer. The freezer will meet it's temperature setting first before it opens the fresh food section damper.
A balanced system will save on your electrical bills. The compressor will kick in only when demand is met. Your compressor should not be running continuously.
Oct 23, 2014 | Bosch KGN34VW20G White 280 l Fridge...
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
I have a Matag Refrigerator Model MTB2156DEW. The freezer is located on the top of the fresh food compartment. For approximately a week the refrigerator has been constantly running without cycling. ...
Defrost the unit. The fridge section cannot cool if the freezer is iced over since the fridge gets its cold from the freezer. If you don't have a second fridge use a hair dryer to speed the defrost.
Apr 06, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Why did it stop cooling? (My husband used a steamer to clean the fridge section, after it had been unplugged for a while. I brushed & vaccuumed the coils, thoroughly.) The lights come on, so there's...
Good day,
I don't know how long it was off, but using a steamer in the fresh food section could cause a lot of issues.
The thermostats and defrost controls, some being electronic, don't handle moisture well.
The first step would be is opening the freezer door and see if you hear the fan motor running. If not, back in the food compartment, the first step is to access the thermostat itself and test it for continuity. You'll need an ohm meter for that test. If it tests closed (zero) ohms than post back to me.
But it's important I know the down time, and how soon the start cycle was initiated after the cleaning process.
Jun 15, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
The refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Nov 12, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
