Question about Maytag 24 in. MDB7601AWS Stainless Steel Built-in Dishwasher
I have an MDB760 dishwahser making a lot of noise
I have an MDB760 dishwasher that was installed 2/2008. It has started making a pretty loud noise whenever it is sloshing the water around. I am afraid it is the pump motor. Can you give me any advice, please?
  • Maytag Master
  • 3,247 Answers
The pump is not turned on when the what is sloshed around. It is the wash motor which turns the arms around. It is likely something is stuck under the washer arms or the washer motor bearing is faulty.
If the dishwasher is only about 2 years old, I would suggest you call Maytag for warranty service. Depending on the part they will have different warranty time period. Normally 2 years should be a general policy .
Posted on May 08, 2010
Dishwasher
Start the machine and make a movie ..
I just want to hear..
can be a lot of reasons..
wash or rinse arms...
wash motor..
rinse motor..
Good luck
Jun 18, 2013 | Dishwashers
Very noisy wash cycle
most times i have found a foriegn object in the pump. sometimes the machine will clear it itself but other times you have to take the pump apart. it is not too difficult but you will need a size T15 and T20 Torx aka (star) bit to get it apart. Just keep taking out screws until the filter flowplate lifts off.
Nov 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
The dishwasher works very loudly.It cleans the dishes very well, just the noise is extremely loud.
Though Noise depends on the model and make of the machine, still you can use the below methods to minimize the noise :-
  1. Ensure the dishwasher is level. An unleveled machine can cause unwanted vibration noise in addition to dish rattling. Most appliances have leveling feet that adjust to ensure that the appliance is level. Ensure the machine is level. If you can't access the feet, call a professional.
  2. Install insulation around the dishwasher. A sound-absorbing foam can diminish dishwasher noise level. Unless you are familiar with how to remove or install dishwashers, have a professional perform this task.
  3. Load dishes securely. One sure fire way to cut down on dishwasher noise is to load the dishes properly. Cups, saucers and other items that aren't properly placed in the dishwasher can toss about by the jet streams of water. Put small items in a dishwasher approved, screened container to prevent them from getting caught in the dishwasher's cleaning mechanisms.
  4. Purchase a quiet dishwasher. Some manufacturers make dishwashers with built-in noise reduction features. Research and read reviews for each to determine which one works best in your situation. Magazines like "Consumer Reports" provide unbiased reviews that can be helpful.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 03, 2009 | Whirlpool Dishwashers
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
HDA3400G020WW noise
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
Mar 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Noise from dishwasher
Dishwasher makes loud noise in begining. How do I remove lower spray arm to see if something is stuck? Whirlpool DU1055xtpb4.
Jan 14, 2009 | Whirlpool Dishwashers
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Loud noise
Very loud squeaking sound, at the start of each cycle.
Jan 09, 2008 | Kenmore 16639 Built-in Dishwasher
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Open Questions:
Maytag 24 in. MDB7601AWS Stainless Steel Built-in Dishwasher Logo
166 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
