When I start (any cycle) our Frigidaire Gallery Series GLTF2940ES front loading washer, the machine runs for 1 second (water comes in in wash cycles or drains in drain/spin cycle) and then the function stops. The machine continues to make a low humming noise, the clock will go down one minute, but does not change after extended times. Your advice would be appreciated.
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: Frigidaire GLTF2940ES stopped with Error
Onthejob5130 is right, the machine use E23 too tell you that the pump is obstructed.
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
