Will Not Turn On
Got Toshiba M50-130, it will not turn on i have had new power supply and new battery but it still will not turn on. when i press the on button it usually goes blue up it doesnt even do that. but what i do get is the mains lcd flickering im not sure what this means. any ideas??
  • Anonymous Mar 27, 2008
    thank you for posting. i have tried the external monitor and nothing its not the display because it will not turn on at all. It used to for a few seconds and then turn off. i also get a clicking sound coming from around the intel chip or the lcd mains when its flickering
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Connect external monitor and check if its works or not ,if ok your display will gone,still same problem i think motherboard problem
Posted on Mar 27, 2008
6ya staff
SOURCE:
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
Charges but lights flicker when trying to turn on then lights turn off and nothing happens.just bought new charging cord oem.
Not all oem's are created equal, this sounds like a power supply issue. I would be tempted to try another power supply, first remove the main battery and press power, if it comes on the rechargeable battery is bad, replacement only option.
May 03, 2012 | Toshiba Satellite A105-S4284 Notebook
Wont power up
try to turn off the laptop, then remove cables and battery. Then press and hold the power button for 8 secs. Reinsert the cables and battery and then turn it on. If didnt work, try to call toshiba since this would be a power supply or motherboard problem...
May 07, 2011 | Toshiba Satellite M55-S135 Notebook
I have a toshiba x205 sli-5 and i think it overheated from sitting on a bed.Now i try to boot up and it beeps 3 times and no display or sound
Greetings,
The BEEP code usually indicates a problem with your memory, cpu, power supply or motherboard.
With your power plugged in, try pressing the power button for 10 seconds.
If your power supply light is blinking unplug the power and remove the battery. Then without plugging in the power cord, reinsert the battery and turn on the computer and see if it boots up. The AC adapter may be defective and need replacing. Your battery may also be defective. You may need to contact Toshiba support at http://pcsupport.toshiba.com
Apr 17, 2011 | Computers & Internet
Won't turn on with or without the battery
try this
remover battery
disconnect power supply
press & hold power button 60 seconds, then release
replace battery & power supply
restart
Dec 04, 2010 | Toshiba Satellite PSAFGU-048002 Notebook
Toshiba satellite A200 - press power to turn on the machine and get blank screen and 3 beeps then nothing. Computer was left in sleep state for approximately 2 hours and now refuses to wake or reboot...
HI
Try to unplug the power supply and take the battery out. so it means there is no power going to the laptop. now press and hold the power button down for approximately 1 minute.
After that put the battery in and plug the adapter back.
Try to turn the laptop on most probably it will come on
If it still does the same thing contact ur laptop manufacturer
Jul 18, 2010 | Toshiba Satellite A200-16J01D Notebook
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite A105-S1013 no power
Try taking out the battery pack and using power supply only. If it boots, turn off laptop and try with battery again. If works, great, if not your battery my be faulty and you'll need a new one.
Jul 31, 2008 | Toshiba Satellite A105 Notebook
My PC not turn on
Toshiba Pocket PC e310 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (19 of 104).
Sep 08, 2005 | Toshiba e310 Pocket PC
My PC not turn on
The Toshiba Pocket PC e330 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "DC-In Socket". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (20 of 105).
Sep 08, 2005 | Toshiba e330 Pocket PC
Open Questions:
Computers & Internet Logo
49 people viewed this question
Ekse
Marvin
Marvin
