Question about HP Computers & Internet
When i sign in its camming this bage is expiered
  • HP Master
  • 11,800 Answers
Your security software has expired - replace it immediately.
Posted on May 11, 2010
I have changed the battery , alternator, spark plugs. fuel filter,coil packs, crankshaft sensor . tested the ignition module. and it still wont start. it turns over but just goes rrrrrrr and nothing ?
I am sorry you have already done all that work! You need to check the cam sensor magnet on the cam gear. You can remove the cam sensor which has 3 wires going to it and is mounted behind the belt near the waterpump. the magnet will sometimes break off its holder and that will keep the engine from starting as it can not sequence the fuel injectors. if the magnet is ok then you probably have a bad timing chain and gear. That series 3.8 buick engine has a camshaft gear which has an aluminum gear with PLASTIC teeth. Yes plastic teeth. The plastic becomes old and brittle and breaks off leaving you with an engine that wont start. Dont feel bad or dumb for replacing what you did as I have seen many TECHNICIANS who have done the same thing as I have worked for the G.M. dealer for years. I give you credit for doing what you could! Unfortunately you will probably have to replace the timing chain and gears. It is not a SUPER hard job but expierence in doing this type of repair is recommended. If you DO do it yourself, Make this one note. The 2 bolts holding the cam gear to the camshaft are TWO DIFFRENT LENGTHS! The longer one goes thru the cam sensor which is mounted on the face of the cam gear. Good luck! Scott
Please rate my answer good or bad - Thank you
Sep 17, 2011 | 1987 Oldsmobile Delta 88
I can not sign in my hotmail inbox.Some urgent mail are there ,really need your help.My hotmail address is ocean_see@msn.com and I locate in beijing
hi
have configured in Out look or you using web bage mail if your using web bage the you have to contect hotmail support
if your using outlook then i can help you
Jul 07, 2010 | Microsoft Windows XP Professional
Vac light comes on after i changed the bag
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
http://evacuumstore.com/
Apr 14, 2010 | Electrolux Lux 5500 Canister Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
The red light on my electrolux vacuum comes on and cuts power.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Me my freind cant find team roket after you beat the boss at the earth bage gym!
You can't find him because the Gym leader was the boss of Team Rocket. Once you defeat Giovanni team rocket disappears
Jun 28, 2009 | Nintendo Pokemon Red
Does not print
get a new cartrige
Feb 11, 2009 | HP DeskJet 820Cse Printer
Electrolux 2000 Mod# c151c
Turn the knob on top all the way to the right
Jul 04, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
