Question about Basco Deluxe Sliding Glass Shower Door / Tub Door Clear Glass , Silver Finish Hei
Shower door off track
The inside door is off track
  • 31 Answers
It's usually best to take the OUTSIDE door off in that case; and start from the INSIDE, then do the OUTSIDE. The track wheels MAY be reversed on IN/OUT, so watch how they hang in the track. When everything is off, it's a great time to scrub out all the "yuck" that grows down in there. Once that's all cleaned out, rehang the INSIDE door and get it going smoothly, then the OUTSIDE door. You're all set then.
Posted on May 09, 2010
Replace hollow gasket vista-pivot ii shower door
Usually the bottom of most framed doors has a chanel which contain door sweep or hollow gasket,all you have to do is pull it and slide the new one in the same place.
Please note that some times the end of the chanel is crimped to prevent the gasket to move in and out of the track.
I hope this will help.
Nov 30, 2013 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have a shower glass door which has three doors. One of the door always comes off when I slide d open
most shower doors are held in by the rollers some are adjustable if yours arent check to see if the spring is still holding wheels out firm if not spring probably broke
Dec 12, 2012 | Home
I have a Maax Neo-Round Corner shower that leaks under the track the doors slide on. I have caulked inside & out but still leaks. Any suggestions????
You may have to remove the doors and the track and reinstall the track on top of a "bed" of caulk or sealant to prevent migration of moisture underneath. The leakage also may be caused by moisture running down the inside of the doors during active showering. Check also for warpage in the track that would cause it to seal unevenly
Nov 10, 2012 | 2003 GMC Envoy
The inside shower door is uneven, making it come of the hinge after moving it more than 4-6 inches.The metal attachment holding the glass is lower than the other ones.How do I get it even so it slides...
The top rollers should have adjustments on them to bring the door to horizontal as it swings accross the track.
Start with door in the middle and adsust by seinging it to both sides.
Dec 02, 2010 | Basco Deluxe Sliding Glass Shower Door /...
I installed a new bathtub bypass shower door and the outside glass doesn't slide smoothly. It seems to bind in the middle of the bottom support track; it moves, but not as freely and quietly as it should.
Please clarify - you said it's a pivoting door but also said it doesn't slide smoothly - can't really do both at the same time. If it's a typical bypass sliding door then you should be able to make an adjustment to the hanging brackets on the offending door to raise it up off the track. If all else fails the header track can be raised thereby making the doors hang higher and off the track attached to the tub surround.
Oct 28, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Sterling frameless bypass shower doors inside door wont stay closed even though have it on th best option setting to do so
Some times it's possible to tweak a roller track (barely bend) at the proper spot to prevent the roller from back tracking past that spot.
Sep 17, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Need installation instructions for sliding shower door...probably #5475. When reinstalling, the inside door is swinging with nothing to secure the bottom.
not sure what you mean when inside door "swings" on a "sliding" door,...i'll assume you need the "inside door guide", a little plastic piece that screws with one screw to the main threshold,.....
Nov 02, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
Basco Deluxe Sliding Glass Shower Door / Tub Door Clear Glass , Silver Finish Hei Logo
499 people viewed this question
Top Basco Home Experts
Donni Steen
Tom Chichester
Are you a Basco Home Expert? Answer questions, earn points and help others
