Question about Canon BubbleJet i560 InkJet Printer
Ink absorber how do I deal with the ink absorber when full
  • 4,041 Answers
Hi
Try this see if work for you.
Canon i560,
Dont forget when you have time you will need to clean out the ink pads, or it going to over flow.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
How to replace ink absorber canon mx310
Unfortunately this is not an end user item. The ink absorber is basically a big felt pad. When the printer cleans the print heads at the beginning of the print cycle it spray ink on the pad o clean the printhead nozzles. The printer is programmed to count these cleaning cycles and when the number is up it gives the ink absorber error on the display. The printers use the ink absorber to prevent the used ink from dripping out of the printer onto you table or desk. By the time the absorber registers that it is full it really is soaking wet with ink, you don't want to deal with that mess. It really is like an end of life for the printer notification. You would have to open the printer, remove and wash the absorber and clean the holder then reset the counter in the printer just to get t going again. The manufacturers don't even sell the absorbers because they treat this as a non-repairable printer. Sorry for the news but I have been a printer tech for 15 years and that's really the best thing to do, get a replacement printer.
Jul 19, 2012 | Canon PIXMA MX310 All-In-One Printer
WHAT IS AN INK ABSORBER
The ink absorbers are a set of rubbery pads that absorb the ink during the printer cleaning cycle. They can also absorb ink from borderless prints (where the ink goes out to the edges of the paper). Some of these pads are below where the print head goes when in standby mode. Additional pads are further down inside the printer.
To get at them, you need to disassemble the printer and it's a messy job to replace or clean them. The counter for the waste ink pad full is set to a value that usually should be reached near the expected end of life of the printer.
If the printer is still under warranty, contact Canon to have them deal with the problem and reset the printer.
I hope this helps.
(You may be able to find the reset command by Googling waste ink full and your model number.)
Jan 09, 2012 | Canon PIXMA MP170 All-In-One InkJet...
INK ABSORBER FULL
Your waste ink absorber is FULL. So you need to replace your waste ink absorber to the new one.
This problem can not be solved by the user. You must take or send it to a service centre, where a technician will remove the old ink absorber, clean up any internal ink mess and enter a reset code to clear the "ink absorber full" condition.
May 27, 2011 | Computers & Internet
"ink absorber is full contact
while the ink on the ink absorber is submitted and must be cleaned. disassemble the printer until the ink absorber is reached, remove the ink absorber, with an alcohol solution to clean the ink dissolve deposits. It is better to make this a specialist
Mar 31, 2011 | Computers & Internet
Triangle and ON/OFF switch both flashing. Window reads 'CHECK PRINTER'. What exactly do I check? Window had been reading 'WASTE INK NEARLY FULL' for a fortnight, but I couldn't find out how to deal with...
The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc. http://support-nz.canon.co.nz/contents/NZ/EN/8000137103.html
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Absorber is full
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps .... Cheers :)
Jul 15, 2009 | Canon Pixma iP4500 InkJet Printer
Canon ip1800 ink absorber is full, cannot remove Cartridge
Hi ...
Please vote if this helps ... Cheers :)
Jun 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon ip4500 says that the ink absorber is full contact the service centre
Hi ....
Do vote if this helps ... Cheers :)
Apr 29, 2009 | Canon Pixma iP4500 InkJet Printer
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Canon BubbleJet i560 InkJet Printer Logo
1,045 people viewed this question
old marine
old marine
