Question about Maytag Atlantis MAV6000 Top Load Washer
WHILE WASHING HAD TO STOP WASHER START SMRLLING RUBBERY SMELL WHAT COULD IT BE BELT?
  • Maytag Master
  • 8,220 Answers
MACHINE WILL NOT SPINNED
It sounds like you need a new belt for your machine.
Oct 22, 2012 | Speed Queen AWS45NW Top Load Washer
Maytag atlantis series mav6200aww, there was a burning rubbery smell today when it was in the spin cycle. I turned it off and unplugged it what could it be
could be a belt and or the pulleys under the machine are plastic so one of them could have melted along with the belt smoking. could be something in pump or look in washer and see if there mite be a nail or something like a nail in one of the little holes in the inner tub . the nail could be making the machine not spin and could be causing the belt also to smoke.
Apr 01, 2012 | Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
How to access my washer belt?
Tilt the machine backwards, the belt is accessible from below, remove and replace no tools required, just pull off and fit the new one, the motor pulley is spring loaded so will move to give enough slack.
Dec 15, 2009 | Admiral AW22 Top Load Washer
Buning smell whenever I use my vacuum
If it's a rubbery burning smell, check the belt for the beater, it could be rubbing on the sides or even broken.
Jun 22, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Whirlpool Inglis washer super capacity, 8 cycles, 2 speeds. Bought in May 2008. Works well and washes well, but it is VERY loud and seems to be getting louder and now there is a faint rubbery smell when it...
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
Jun 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Jan 04, 2009 | Maytag Washing Machines
Maytag neptune 98 burning smell
check to see if the door boot is intact. if there is a hole in it water could be getting to the motor control board and you are in danger of shorting the machine out. the other possibility is the main computer board may be on its last legs and is doing a slow sizzle
Sep 18, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Atlantis MAV6000 Top Load Washer Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
