Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Replacing drive and auger belts on a John Deere 1032 snowthrower
It appears to remove and replace the belts, at least 1 pulley needs to be removed to make room to pass the belts between the pulleys and past the levers. Can you replace the belts without the major pain of removing 1 or more pulley's and the lever mechanism?
Thanks
Paul
    President:
  • 1,627 Answers
You don't need to remove the any lever linkages but you will need to remove some of the pulleys.If you can give an exact model number of the tractor it would help.
Posted on May 08, 2010
  • Anthony Harper
    Anthony Harper Dec 23, 2013
    How about for a JD1130SE. I broke the auger belt. How do I get it routed back under/around??
Tip
How to replace belts on a snowblower and removal of auger from housing.
hello,, How to replace the auger drive belts on a MTD,Yard Machine,and other two stage snow blower,that don't allow enough room to slide belts between the pulleys.
1.Tilt machine up on front end to remove the bottom frame cover,there should be six screws to remove,tilt back up right.
2.Remove the chute crank from the left handle and from the shoot.
3.Remove the black belt cover,there should be three screws.
4.Remove the support guide bracket,that the cable is running through,and remove cable end from idler pulley arm.
5.Remove belts from upper pulleys. (hint if there is a bolt holding the pulleys on it is easier to remove the bolt and slide the pulleys off to be able to remove the belts.)
6.Remove the six bolts and nuts holding the front half to the back half together,slide front part out to be able to remove old belts and install new belts. (hint make sure you get the new belt under the belt keeper on the bottom.)
7.Reassembly in reverse.
8.Set of two belts 0.312x34.75, part number 954-040B, $30.28
This first part is for replacing belts.
To remove the auger assembly completely follow these steps.
1.After removing the belts,and separating the two halves, remove the bolt holding the pulleys on,pay attention how bolt comes off and the way the washers are on be sure and put back on the way they come off.
2.Remove the pulleys and make note how they come off of the adapter pulley.remove pulley note how comes off.
3.Remove the bolts and nuts on the side of the housing.
4. Pull the auger out and place on work bench,making note how the end parts come off.
5.Remove the shear bolts to get and slide augers off, be sure and mark which way they turn as not put back on backwards.
6.You can access the auger gears by removing the bolts,to make repair.
7.also check the ball bearing in the rear housing where the auger shaft goes through to make sure it is not egg shape,if egg shaped needs replacing.will cause belts not to stay on and jump off the pulleys.
8.Check the end hex flange bearing (the plastic piece) to see if it is out of round,if is replace it.
9.Also you can download your manual if you don't have one depending on your model and number.
hope this helps,DON'T FORGET THE 4 THUMBS UP,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
How do I install brass bushings in a sproket bracket on QA-42A snow thrower for a cub cadet
Hello, How to replace the auger drive belts on a MTD,Yard Machine,and other two stage snow blower,that don't allow enough room to slide belts between the pulleys.
4.Remove the support guide bracket,that the cable is running through,and remove cable end from idler pulley arm.(Note ,on some machines the pulley can be adjusted by loosing and move pulley towards the belt, than retighten.)
9.Also you can download your manual if you don't have one depending on your model and number.and also you can check the shear pins in the augers if the above is not the problem.
hope this helps,,any comments welcome,thank you. @@
Feb 15, 2012 | Garden
How do i replace the drive belt on a john deere L110 riding mower-any diagrams? thanks-wasnt in the owners manual
For round fender 110. To remove \ replace drive belt that has slipped off. Remove 2 of the 3 bolts from large pulley on transmission right side. This will allow enough access to slip belt onto pulley. Replace bolts. hope this helped Tim
Mar 19, 2011 | John Deere Garden
826LE Power Max Snowthrower_ Drive belt keeps coming off
part # 94-8812 is traction belt 106-4498 auger belt
There is a service bulltin on this I have not seen this yet, Ill paste it for you to look at .
this was issued dec 22-2003 you would think that it would have shown up as a problem by now.
UNITS AFFECTED: Model Number(s): Serial Number(s):
38620 240000001-240999999
38621 (Int'l.) 240000001-240999999
38632 240000001-240999999
38635 (Int'l.) 240000001-240999999
38642 240000001-240999999
38645 (Int'l.) 240000001-240999999
38652 240000001-240999999
SUBJECT: Traction belt jumps off the pulley.
SITUATION: Incorrect pulley alignment causes the traction belt to jump off, usually when the drive is disengaged or as a hill is crested.
CORRECTION:
1. Remove the belt cover, engine belt guide and the bolt securing the crankshaft pulley.
2. Remove the auger brake assembly.
3. Remove the crankshaft pulley and the auger belt.
4. On the left side of the machine, remove the hair pin cotter from the speed control link and slide the link out of the pulley pivot assembly. The traction belt can now be removed.
5. Shorten the pulley half nearest the engine (PN 106-7334) shown in Fig 1. Grind or machine 1/8” (.125”/3.2mm). from the hub end of the pulley. The new finished length of the pulley half should be 1.07” (2.7cm).
6. Chamfer the bore to ensure the pulley fully contacts the shoulder on the crankshaft. You can send the pulley to an outside machine shop if you do not feel that you can modify the pulley in house.
7. Reinstall the pulley with a new traction belt.
A. Chamfer edge after grinding/machining.
B. Remove 1/8”.
C. Masking tape used as a reference line.
8. With the engine off, engage both the traction and auger levers and inspect the alignment of both the auger and traction belt idler pulleys (Fig. 2). Since we have moved the crankshaft pulley it may be necessary to bend the idler arms slightly to center the belts. Adjust as needed.
9. Install the engine belt guide and test operate.
10. Install the belt covers.
PARTS: P/N 94-8812 Traction Belt
Feb 04, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
491 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
