Question about Admiral AW22 Top Load Washer
Washing machine does not spin.
My admiral top loading washing machine does not spin
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. The motor coupler may be broken. Many washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. A belt may be broken. The clutch may be worn. It may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Replace whichever part has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 08, 2010
  • 90 Answers
SOURCE: Admiral Washing Machine not spinning
Make sure the safety switch that the lid operates is getting pushed down. Use a popcicle stick or non metalic object to push the switch in and try to get it to spin. This switch goes bad alot. It is in a wet environment. You will normally hear or feel a click when the switch is depressed. If not, use a putty knife or butter knife to push the top retainer in that are located at the front outer corners in the gap just where the top of the machine meets the rest of the unit. While pushing in you should feel a slight resistance but it should spring in and allow the top to lift up. Make sure to unplug the unit first.... Find the switch and unplug the two wires from it and use something like a paper clip or small wire to connect the two wires together. Let the top set back down, doesn't have to snap down and try to get it to spin again. If this works then the switch is bad... There are plastic parts on some machines that push this switch when the lid is closed that get broken off without you noticing until it just doesn't work right..
Posted on Feb 10, 2008
SOURCE: Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Posted on Sep 14, 2008
donnastr
  • 10 Answers
SOURCE: Admiral Top loader leaking water
water inlet vale has internal malfunction
Posted on Oct 08, 2008
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
Posted on Aug 04, 2010
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Not spinning properly there is still a lot of water in clothes after spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Admiral Washing Machines
WONT SPIN THE WATER OUT ADMIRAL LNC6443A80 WASHER
heatman101
Aug 10, 2011 | Washing Machines
Won't rinse/spin
heatman101
May 06, 2011 | Admiral AAV7000A
Admiral top load stops spinning after about 20 seconds when trying to spin to empty water
Check the drain pump on the bottom of the unit often the hose will block causing this issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Admiral AW22 Top Load Washer
What do i have to do when spin does not work?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 24, 2010 | Admiral AW22 Top Load Washer
Admiral washer will agitate but will not spin dry
heatman101
Sep 19, 2010 | Admiral AW22 Top Load Washer
Have a admiral washing machine sounds like something is grinding inside while washing and spinning
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 08, 2009 | Admiral AW22 Top Load Washer
Admiral top load 10.1 Kg 4 speed Combo has become
water does not stay in drum goes straight out?
Jun 04, 2009 | Admiral AW22 Top Load Washer
Jul 20, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
201 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
