Question about Sony CLIE PEG-T665C Handheld
I have a Sony Clie and I want to replace the battery and I all ready unscrewed all six screws on both sides but the back still wont come off. Is there another screw?
  • Sony Master
  • 6,993 Answers
there is no other screw, the cover is clipped together, that's why you cannot remove it.
Use a flat screw driver to open it from the sides that is clipped together, you need to apply force in order to open it.
You could still further check for any screw, but I doubt if there is any.
Good luck.
Posted on May 08, 2010
Tip
Does anyone know of online battery replacement instructions specifically for a...
WARNING: DO NOT ATTEMPT THIS OPERATION UNLESS YOU DO NOT PLAN TO UTILIZE A WARRANTY AND OR INSURANCE. OPERATION WILL NULLIFY 1: Buy a new battery for your specified pda model(EBAY,AMAZON) 2: Preform a pda to pc sync if possible 3: Buy or or make sure you will recieve a pda screw driver 4: Unscrew back, be gentle 5: Gently remove back with a flathead screwdriver 6: Locate the battery cable 7: Disconnect the battery from the pda 8: Connect new battery/ reattach back
on Feb 25, 2008 | O2 Xda Atom
Batteries
Unscrew the six small screws on the back with a small phillips cross head screwdriver (an eye glass screwdriver works fine), then carefully prise off the back using a flat blade in the two slots at the top of the calculator.
Keep it upside down or the display will fall out!
You'll see the two 1.5 volt alkaline batteries there, GPA-76 type (flat, round) in mine. Ease them out carefully and replace them, positive side up.
Alternative battery codes (manufacturer dependent) L1154, AG13, GA13, AG76, GP76A, 675HR, LR1154, LR44 per battery web sites, maybe others.
Make sure batteries are seated and display is in its correct position, replace back cover and six screws.
Caveat 1 : You can buy the TI-30XA for about $10-$13 at Staples/Amazon, two batteries will set you back around $5-$7!! But they last a couple years even with heavy use. TI-36X and TI-30X IIS are better calculators and have solar cells as well.....but about twice the price at $17-$25.
Caveat 2: I had one of these where the display faded, replaced batteries, did nothing because circuit board or display was bad. So you could replace batteries and waste the time/money.
Nov 19, 2008 | Texas Instruments TI-30XA Calculator
Change out a battery in a t665c clie
It was like looking for a needle in a haystack but by doing a search on the internet I finnally found site that had info on how to change out the battery for my modle of clie.
Nov 16, 2008 | Sony CLIE PEG-T665C Handheld
Screen Calibration
Check for protective film/screen debris build-up around edges.
Check for loose cabling plugs into the back of the Screen
Unscrew the four little fascia screws & lift panel out.
I had same problem after unable to enter password.
Did Hard reset, encountered the stylus calibration cycling error.
One of my screen cables had come adrift slightly at one corner.
Jul 29, 2008 | Sony CLIE PEG-N760C Handheld
Sony Clie PEG-NX70V/U
I believe that the battery door is located next to the hold button. you need to use a cross screw driver to access and pull the battery. i havent try it, but i am going to acquire a battery to replace mine.
May 12, 2008 | Sony CLIE PEG-NX70V Handheld
Clie T615 not reading memory stick
Either the stick is defective or the wrong format.
May 04, 2017 | Sony CLIE PEG-NX60 Handheld
Problem with Sony Clie - NX70V/E - battery
i just replaced the battery on my NX60. It was a very easy task. Look on the net for batteries. I found a battery for $18 plus S/H. It came with the special plastic screw driver and instructions. I just threw everything away or I would give you the company name. I found several. The instructions are easy. Simply remove the screw ofr the barrtey compartment and all the scrws holding on the back. Remove the back, carefully remove the battery, carefully replace the battery making sure you place the wires in the correct position. Replace the back and screw the thing together. You can also order a battery from Batteries Plus. The original battery in my machine was 1000 ma the newer batteries are 1200 ma. Good luck.
Mar 05, 2007 | Sony CLIE PEG-NX70V Handheld
Sony Clie sj33 battery
If you haven't already done so. Try resetting PDA in back, if that doesn't work go back to battery and verify connections are correct and check connection wires (they may be frayed or damaged). I'm not sure that will solve the problem, but it worths a shot.
Sep 19, 2005 | Sony CLIE PEG-SJ33 Handheld
Open Questions:
Sony CLIE PEG-T665C Handheld Logo
99 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
