By pressing power button it is powering on or not if yeas the display light is comming or not? if yes then what is the bios error code please check. If not powering on then remove the battery plug in power adapter and press power button if not on then it is hardware problem go to service centre
Please remove the battery and ac power adapter. hold power on button for 1-2 minutes. Then try to power on laptop with ac power adapter without battery. check the display of laptop.
If not check the dc voltage of the ac adapter. is it the same voltage as written on the ac power adpater. if not same please try with another adapter.
If not remove the hard disk and ram. clean the fan,ram. Reinsert ram and power on with ac adapter. check the display.
Please check with external display if laptop is turned on but no display.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
1. Use a different power outlet. Maybe the outlet is bad. 2. Check the ac adapter. check if the light is lit. The light is a power indicator. If there's no power on it, then, you have to make sure that it's not broken or it's connected properly to the power outlet. 3. Check for any power indicators in the laptop. Like lights lit or the charge indicator. If there's none, then, the laptop is not receiving any power. It might be caused by a defective battery. 4. Remove the battery. Plug in the laptop to the ac adapter without the battery on it. Check for power indicators. Press the power button.
Let me know if there's any development. Leave me a message in this post.
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD is faulty and need to replace.
You may first try performing the steps mentioned below:
1) Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook. 2) Verify the correct AC adapter is being used, and not a third-party replacement AC adapter. 3) Do not connect the AC adapter to a surge protector or extension cord. 4) If the DC jack on the computer is loose or damaged, the computer may require service. 5) Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged, or the LED is not lit or continuously flickers when plugged into a working AC outlet, the adapter must be replaced. 6) Attempt to turn on the computer normally. 7) Press and hold the Power Switch for 5 seconds. 8) Remove the battery. 9) Disconnect the AC power adapter. 10) Press and hold the Power Switch for 5 seconds. 11) Connect the AC power adapter. 12) Attempt to turn on the computer. NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours. 13) Disconnect all external devices that are connected to the computer. 14) Attempt to turn on the computer. 15) Remove any additional Random Access Memory (RAM) that was installed in the computer. 16) Attempt to turn on the computer. 17) The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
1. remove all ext peripherals 2. remove battery 3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop) 4. try any other wall socket check if ac adapter will led stay on 5. if ac adapter stayed on then connect to laptop (without the batter) 6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage. 7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber) 8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink. 9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Black out?
Please stop the laptop by pressing the power button until it stop.
remove the battery
remove the memory and then after 15 minute insert back the memory and install the battery.
If the system display windows, and the problem is always start when plugging the ac power. maybe the battery of the laptop is damage.
Please try go to bios setup and then at the power option, find the restore the "last state" something like that and the set it to "off: option.
