Question about Toshiba 27A33 27" TV
When i turn the tv on it is black with a very slim image in the middle. Half of the the image is upside down. the picture then stretches out until full size. this takes about 30 minutes. When fully stretched however in cuts off the tops and bottoms.
TVtechmaniac
  • 140 Answers
SOURCE: Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Posted on Sep 16, 2007
SOURCE: Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Posted on Sep 12, 2009
  • 9 Answers
SOURCE: picture is only in middle of screen, top and
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
johnnydiode
  • 647 Answers
SOURCE: only thin white line across my toshiba tv
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 28, 2009
SOURCE: Toshiba 36A50 Horizontal Line in the middle
toshiba 36a50 i have problem just i turn off tv but turn on dont work tv only red light flexing only no sond on picture
Posted on Dec 21, 2009
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Emerson TV LF501EM4F picture upside down
there's a software upgrade on emerson's site that corrects this problem.
Jan 21, 2014 | Emerson Televison & Video
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
Will turning your television upside down damage your television?
No it will nNo it is not. In fact some televisions are designed with this in mind. Usually this is done with smaller televisions that will be mounted. On those televisions there will be a picture flip or reverse image/invert image setting. I have spoken with bewildered seniors with upside down pictures and advised them to simply press picture flip until their image is right side up again. There are some customers that mount their televisions in bathroom mirrors or on the ceiling, under kitchen counters, and etc. who have found this to be most helpful.
Jun 13, 2011 | Televison & Video
Heard loud popping sound with tv off. When I turned it on the picture stretched across screen with a dip in the center. Started ~ 4 months ago. The video picture does not show centered on screen(the...
Sorry the problems u have is not for hobbiest or amature to do.High voltage Deflection board areas.This problems,must have experience tv tech to troubleshoot and replaced parts or boards require for the tv.Could be extensive repairs or just requiring test and replaced some of many small capacitors,resistors,transistors and ICS.Have to do major troubleshooting though.Must get priced quotes by many big screen tv shops,than u decide,which to give the job to.
Dec 09, 2010 | Samsung 50" Slim-Depth DLP HDTV
My LCD TV at random times has lines that go through the lower half of the tv
This is caused by the screen sliding during shipping and should be addressed as soon as possible. Get a helper to pick up the other side of the set with you. Place a towel on the table it is on turn the TV upside down and gently bump the top side of the TV on the table until it settles. I know this method sounds a little weird, but it will save you the cost of replacing a screen down the road. What is happening is that the molded plastic supports are pinching into the mylar data or power cables affixed to your screen, and they will eventually stretch and separate.
Mar 09, 2010 | LG 32LG30 32 in. LCD HDTV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 27A33 27" TV Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
