Question about Yamaha 4500 Watt Electric Start Generator - EF5200DE
With my generator running i have ac power but my ac does not come on
  • 349 Answers
Make sure your generator is rated high enough to run you a/c. Also is you a/c 120v or 240v? Do you have it plugged into the right voltage?
Posted on May 12, 2010
Honda. eg550 generator
I would say the AC is overloading the Generator. AC units require ALLOT OF POWER.
May 16, 2017 | AC Cars & Trucks
If I have a portable air conditioner that uses around 7 amps to run, how big of a generator do I need to run it, ( ex. 2000 watt, 3000 watt, etc.) Thank you!
If you live in the USA or another country that uses 120V municipal power, then the AC uses about 800W and you SHOULD be able to run it (including starting the AC, which takes a lot more power than keeping it running once it's started) with about a 1500W to 2000W generator.
Jul 17, 2014 | Electrical Supplies
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
Why do my clocks run fast when my Briggs & Stratton 15kw generator is running?
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Powered from a generator the APC 3000 UPS running on AC power and running on battery lights come on alternately
It is possible that the auto power detect section has gone faulty and is switching in this shunting manner because of an error in the line detect section. The op amp is detecting a low voltage to switch on and doing so it goes back to power. This can be due to a frequency problem in the AC generator and so If you switch off the generator the fault must stop.
If so have the generator checked for frequency change or the UPS has a circuit error. Try to set the AC voltage of the generator up to the required level if there is a drop on load.
Sep 28, 2010 | NEC APC Smart-UPS 3000 RM 3U...
Kohler 12res AC breaker flipping with no error listed
wat size c/breaker
6600 divide 240 = amp
rule of thumb
Aug 16, 2009 | Kohler 12 kW Emergency Power System -...
Coleman 5000 generater-no AC output
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Jan 09, 2009 | Coleman Powermate Powermate 5000W...
Run ac off of generator.
you need to use a volt meter and test which lead from the 4 wire output of the generator a 220 v is coming out.
the round center prong of the ac is its ground and should not be connected to any live power. it could be left unused.
tnx 4 using fixya,
drcool
Sep 27, 2008 | Hampton Bay HBLG5004 Air Conditioner
Yamaha 4500 Watt Electric Start Generator - EF5200DE Logo
102 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
