Question about Canon PIXMA iP90 Mobile Printer
Pixma ip90v Print driver error
Continually the print driver must be restarted. Now it refuses to print. Running XP with usb connection to printer, have tried reloading drivers etc.
    Novelist:
  • 105 Answers
When you reloaded the driver, did you downloaded it from Canon's website? If not, that would be your first thing to try.
Have you ran a utility such as Advanced System Optimizer to make sure you don't have conflicts among your drivers and such.
Posted on May 12, 2008
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I have a Canon Pixma ip90v. My magenta will not print. The others work fine. Anything color is just in a green , yellow, blue tone. How do I fix this
the prin head is clogged,try to go in the driver and try to clean,if the problem persist change the prin head
Mar 04, 2011 | Canon PIXMA iP90v Printer
Refuses to print
Do you solve the problem? Because I have the same probleme and I can't fixed it. Give me a solution if you can. Thank tou!
marcelgiosan@yahoo.com
Feb 12, 2009 | Canon PIXMA MX7600 Multifunction inkjet
Net to download print drivers for canon pixma ip90v
www.findmysoft.com/drivers/Canon-PIXMA-iP90v-x64-2-00-printer-driver.html - 21k
Nov 04, 2008 | Canon Office Equipment & Supplies
Canon PIXMA iP4500 Printer. Sometimes when wanting to print a document or web page, the computer announces there is a serious error on a blue screen and promptly shuts down. The printer is connected by USB...
First of all check for Virus with a latest anti-virus. Also try to plug in the printer USB cable in another port... Try changing USB cable to.. Fully remove printer driver and software and then re-install... Hope for the best...
Plz Rate Me... Thanks.
May 13, 2008 | Office Equipment & Supplies
Ademently refuses to print
I'm assuming you have Windows XP, since you didn't say. Try this:
  1. From Control Panel > Printers - Remove ALL printers.
  2. Unplug USB port and reboot.
  3. Reinstall drivers and software.
  4. Plug USB cable back in.
Hope that fixed ya...
Geno
Apr 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
Refuses to print
Disconnect and switch off printer from pc's usb port. Go to add/remove programmes and uninstall printer software and drivers. Go to printer and faxes folder or go through control panel and ensure the pixma printer is deleted, if not right click and delete. Re-start pc and install drivers from your printers cd rom and re connect printer when prompted and not before (if no prompt when software finishes connect printer). Your pc should then idenitify your printer and auto install drivers. If the same error occurs, it's more than likely a hardware failure, and requires replacing.
Jan 10, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP90 Mobile Printer Logo
69 people viewed this question
old marine
old marine
