Question about Garden
I have a yard machine 42''lawn tractor. It has a 17.5 hp B&S engine that floods seconds after starting. I have to blow the carb out with shop air several times to get it running. Once it is successful, it will be ok for rest of mowing that day. The gas literallt puddles up in the air filter tray when it floods...HELP!
  • 1,498 Answers
Hi Clarence,
Sounds like the float sank. Seriously.
Under the carb is what looks like small cup held on at the bottom by a single bolt. This is the float bowl.
If there is a gas valve turn it off.
If not pinch the fuel line with vice grips or something.
If you smoke, don't. Gas is going to spill out.
Unscrew the bolt
Pull off the bowl.
You'll see a hollow copper ring. That's the float.
Pull it
Empty it.
Solder it
Put the whole thing back together
Thats it
Best regards
Mike
Posted on May 08, 2010
Craftsman 16.5 hp kohler gas in oil
If the machine's fuel tank is located ABOVE the level of the engine's carburettor then it is most likely a "Gravity Feed" fuel supply system .. i.e. no fuel pump reqd.
If that's the case then the carb has 'flooded' at some stage (most likely when engine was not running), and the fuel has simply flowed down thru the carb and into the intake tract, and then down into the sump via the crankcase breather tube. This is extremely common on "low end" brands which, for reasons of economy, are not equipped with low-mounted fuel tanks and fuel pumps.
The reason that the carb has flooded is usually caused by a leaking Needle & Seat (aka Float Valve) in the carb, which could simply be caused by a bit of debris stopping the inlet needle from seating, OR, the Inlet needle may need replacing.
The reason why the engine wouldn't start is simply that it was flooded ... just like cars used to do back before EFI. Drain the crankcase and re-fill with oil, remove the spark plug and let engine dry out overnight, fit a new dry plug, put throttle lever at about 1/4 open, and crank the engine (OUTDOORS!) till it starts. May take a while to fire up, and may be a bit smoky for a while, but it should go.
My advice ... NEVER even approach a lawn tractor with a gravity feed fuel system. There should be laws against them.
Nov 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LTS 1500 lawn mower - model # 917.28903 started sounding funny while i was cutting VERY high grass. I turned it off immediately and it backfired as it shut off. Wouldn't restart. Waited til next...
I would check the big three first of all. Spark, compression and fuel. Sounds like you have spark and fuel. I would get a compression tester to check actual amount of compression. If all three of those things are good I would check valve lash. You will need make, model and serial number of engine. If you post these I can help find specs for you. Good luck.
Sep 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Flooding carb
what has been happening since the fuel blend changed is the rubber tip on the needle valve melts off and doesn't seat change the needle and seat in the carb add a fuel shut off valve and run the carb out of gas when not using it change the oil as well
Jun 03, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The motor floods. If I disconnect the solenoid on Carburator it will start. I reconnect solenoid for just a second begins to flood. Unhook solenoid it runs smooth. Is this just trash in carb keeping needle...
Hi, yes check the needle, seat and float and blow out the carby, basically with the bowl off and the float held level no fuel should flow past the needle, also check that the air filter is not blocked. Regards Phil
Aug 18, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Describe your 20 Hp 42"
The float an needle are stuck open causing the fuel to drain from the tank or be pumped by the fuel pump into the carburetor bowl, filling it and flooding the engine and filling up the air cleaner. You may even find that it has gone into the crank case sump contaminating the oil. Do not run until you have repaired the carburetor and changed the oil and if air filter got contaminated, that changed too.
I hope this is helpful for you.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine seems to be flooding out. I have spark but if you take the plug out it is soaked with gas.
if it's flooding out try starting it without using the choke. if it still floods then the float in the carb is stuck open and you will need to remove and rebuild the carb. they sell complete carb kits for all makes of engines..good luck
Mar 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I can't start my "yard machine" lawn tractor. It'll run for second when I spray start.fluid in carb. I check/clean carb.,replace battery,sp.plug,oil. Check spark, compress. Fuel is in carb bowl., when I...
The carburetor jets are plugged. Complete disassembly & soaking in carburetor cleaner then re install parts after rinsing off & drying them. Make sure all ports are open. Torch tip cleaner is helpful.
Sep 09, 2009 | Yard Machines Garden
DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
