Question about Samsung AS18A6RB Air Conditioner
All the lights flashing
I have samsung air conditioner 12000BTu and all the led flashing
please have any body to help me
because in albania don't have any good technic to fix my problem
best regard
leonard meniku
  • 38 Answers
Problem with circuit software
Posted on May 08, 2010
No, u hv to replace the condenser sensor and remote sensor, but make sure to replace with original samsung parts, if not the problem will come again.
Posted on Aug 27, 2010
LG ac unit red light on pcb flashing 3 times and unit shutting off
This is going to most likely be your power supply circuit board in the unit. If you are handy you can take this apart, remove the board{check the fuse on the board first), get the part number and then do an internet search for the replacement part. I would check Allied Electronics first for this.
Jan 29, 2015 | LG Heating & Cooling
Perfect aire flashes 22 44 77
seems to be trouble codes contact dealer for these codes hand
Jun 28, 2014 | Perfect Aire Import 12000btu Air...
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
LG aircon flashes blinking 8 times and the shifts to timer led flashes blinking light 4 times
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.Air Bulance AC Cleaning Repair Services
Apr 23, 2014 | LG Heating & Cooling
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung AS18A6RB Air Conditioner Logo
1,125 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
