Question about HP LaserJet 5p Printer
Black streaks on printout
I am seeing multiple faint gray/purple streaks of uniform widths (0.2-1" wide along) the full length of each page. Text is being duplicated about 6" below its printed position within these streaks. Light black streaks cover the entire page except for a 1/2' margin on both sides.
  • Tony Walker May 11, 2010
    Does this happen with a different toner/drum cartridge? When was the last time the maintenance kit or fuser was replaced?
    New Friend:
  • 52 Answers
Your fuser is worn out. Needs to be replaced.
Posted on Feb 27, 2009
2 Suggested Answers
  • 277 Answers
SOURCE: black streaks on printout
hi seems like your printer's head is considering retirement not much to do here sorry have a good 1
Posted on Apr 23, 2006
How do i remove a white streak that runs down the
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
May 04, 2010 | OKI C5200n Laser Printer
Printout has a smudge or streak about an inch wide, full length of paper about 0.5 inch from left side.
You need to change toner cartridge for new one.
Most problems of quolity from it.
If is not help you, it may be broken termo fuser - go to service.
Dec 17, 2009 | HP LaserJet 1200 Printer
CL7000 2mm Black Streak on Back Side of Paper
Hello sir; There have a cleaning unit on the transfer belt, replace the cleaning unit should take care the problem.
May 05, 2009 | Ricoh Aficio CL7000 Laser Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
I am getting a faint line all down the page
Most likely you have a defective black toner cartridge. Open the front shutter on the black toner and look at the drum. If you see the drum has toner on it corresponding to the line down the page, you found the problem. If you can't see anything on the drum try printing a page and then interrupting the printout while the page is still in the printer. If you see the line on the page before it goes through the fuser, (the last roller thing on the top of the printer) then it still is the toner cartridge. If it occurs only after the fuser then it, the fuser, is at fault.
Jun 29, 2008 | HP Color LaserJet 2600n Printer
Apr 20, 2006 | HP Color LaserJet 4500 Printer
HP LaserJet 5p Printer Logo
1,844 people viewed this question
Seeker5211
Seeker5211
