Question about Elkay Plumbing
30 year old Elkay bathroom one handle faucet is leaking from underneath. Does this use a replacement cartridge and how can I get a replacement part?
  • 843 Answers
If it does have a cartridge, replacing it would only help it stop dripping out the faucet or from around the handle. A leak underneath is most likely to be a failure of the seal from the supply pipe to the faucet, from corrosion and/or hardening of the rubber seal that is part of the supply pipe connection. Shut off the supply. (Hopefully you have a shutoff valve under the sink.) And remove the supply pipe/tube/hose. This is very hard to do without a basin wrench. (All hardware stores have them, and they are pretty cheap.) Take the supply pipe to the hardware or home improvement store to select a replacement. Other than the material and construction of the pipe itself, and the length, there are only a couple of different fitting configurations.
Posted on May 08, 2010
Elkay kitchen faucet model lk7124 replace stem
ELKAY ' Strainers, Fittings + Other Accessories for the Home
www.elkay.com/strainers-fittings-other
Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
www.elkay.com/
Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
[PDF]SPECIFICATIONS
aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-Arc® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
www.amazon.com > ... > Faucet Parts
Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
Elkay A51947R Replacement Diacore Cartridge with Brown ...
www.amazon.com/Elkay...Replacement.../B0033UX8...
Amazon.com, Inc
Jan 14, 2016 | Elkay Plumbing
How do i remove the stem from an Elkay kitchen faucet model # LK7124?
Leaky Elkay single handle kitchen faucet - DoItYourself.com ...
www.doityourself.com/.../292646-leaky-elkay-single-handle-kitchen-fau...
Can I replace the cartridge (A54236R) from our single handle Elkay (LK-6360) kitchen faucet without removing it from the sink top? If so where is the secret inhex ...
How do i fix my leaky moen bathroom faucet?
Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
Good Luck!
May 21, 2014 | Plumbing
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Facet leaking
You can purchase a replacement cartridge for that... most hardware stores or places like Home Depot or Lowe's will have them. Take in the old acrtridge or the model of thefaucet. Some of them need a special puller to get the old cartridge out..
heatman101
Jul 11, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Leaking bathroom faucet
These single handle faucets tend to need the internal "O - rings" changed every couple of years. Find your model # and take it to Home Depot or Lowes or some similar store and find the "kit" compatible with your faucet. Some kits have a cartridge, some have springs, O - rings, etc. The kit will have instructions on how to remove tha old one and install the new one.
May 24, 2010 | Delta Model 470: Signature Kitchen...
Single handle, about a year old,leaking at the
There will be a set screw on back or under cap on top. Remove handle, next use a phillips screw driver to remove the part that holds on to the cartridge. Then a bonnet that unscrews leaving the cartridge easily repaired or replaced. And there you have it.
Sep 30, 2009 | Plumbing
I have two leaking bathroom faucets. Hansgrohe 06042. I replaced both faucet valves from Hans part no. 94009000. They BOTH still leak steadily. They worked flawlessly for two years.
where are they leaking from?
if they're leaking from underneath, repace the suply lines [between the valve and faucet]. if if from the faucet itself replace your cartrage[s].
Aug 18, 2009 | Hansgrohe 06042 Tango Widespread Bathroom...
Plumbing Logo
209 people viewed this question
Top Elkay Plumbing Experts
jdthefixer
rdjagger
Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
