Question about Samsung SGH-A877 Impression Cell Phone
My samsung impression slider is falling apart, springs falling out and small black rectangular thing-y covering the upper left corner of my keyboard. i do not drop my phone, no water damage, it is in a hard case and i don't use it constantly ( less than 1K minutes a month) though my phone is under warranty, the AT&T warranty center won't replace b/c they say samsung phones don't have this problem, though an AT&T employee says he has seen it often in other phones, other makes and models.
  • 318 Answers
I've seen it in this phone before too. And if you don't fix it soon other parts will start breaking like the flex cable. If you managed to keep everything that fell off, the good news is you can fix it yourself if you are mechanically inclined. The springs just snap in once you get the phone apart. If that doesn't appeal to you, there are some sites you can send it in to for repair, and there are sites like ours where you can trade it in for another phone.
www.usedcellphoneshop.com
Posted on May 08, 2010
Need to know how to remove the cover on the laptop so I can reset the BIOS?
You dont need to remove the laptop cover to reset bios.
Restart your Sony Vaio computer.
Press the "F2" key to enter the BIOS.
Use the arrow keys to highlight the "Load BIOS Defaults" menu option.
Select it by pressing "Enter."
Highlight "Load BIOS Defaults" again and hit "Enter."
This will reset all of the settings of your Vaio's BIOS back to their original factory defaults.
You can now select "Save Changes and Exit" to exit the BIOS.
Hope this helps.
Nov 20, 2012 | Sony VAIO VGN-A170P Notebook
Samsung galaxy s 2 service mode shows a black screen with a small square in the upper left corner
I am not positive this will help you, but this is the only thing I at this time can think of. Here is a video I came across that talks some about black outs. Check out this video. Thanks Mike 2q==
Oct 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
WHERE IN THE IGNITION SWITCH LOCATED ?NOT THE KEY SWITCH !
Take the plastic cover off the steering column, it's a black rectangular piece just to the left and down from the key switch. It is held in there by 2 springs, push these two springs in and the ignition switch will fall down. Unhook the terminals that are hooked to it, and replace with a new one.
Mar 02, 2011 | 2002 Chevrolet TrailBlazer
Instructions to replace the samsung sgh-a877 lcd screen?
needs major work. Do it at your own risk. Did everything right but messed up and broke the tab on the touchscreen cable connector on my daughter's phone. Feel crappy. Will post with pictures later on.
1. remove battery/ Sim 2. remove all screws from the back on the black plastic cover. (6 of them) Leave the ones below the battery. 3. Use the pry tool to remove the back case. 4. remove the motherboard, three connectors, one on bottom left, antenna and top right below the board. board comes off. You also have to remove the power connector (transparent plastic) to what appears to be some hf component (cylinder). there are two wires (red, black), red goes to side marked +. remove with pry tool. 5. Remove all small screws you can see. 6. Remove the shiny plate, keyboard button layer. 6a. Remove the lcd connector screw and the connector. 7. Remove screws from the bottom of the lcd portion of the slider. You can access all screws from the back side. Use the slider to get the back of the phone. There are 5 screws. 8. Use the pry tool to take out the back slider. Be careful with the lcd connector. 9. pull up the black tab on the digitizer connection from the screen 10. remove the lcd 11. use a hair dryer to loosen the glue around the broken digitizer. 12. put the new one in 13. Put all the screws back.
Apr 10, 2010 | Samsung SGH-A877 Impression Cell Phone
Slider sticks
had this happen on my samsung impression press together the front and back portion of the phone to see if the case became misaligned. You should have 8 corners to ensure are snug. If that does not work you might have a broken spring.
Jan 02, 2010 | Samsung Propel A767 Cell Phone
How do I replace the keyboard in a HP Pavilion dv6451us laptop
To start I suggest you have a No.1, and a No.2 Philips head magnetized screwdriver, a small pair of Needlenose pliers, and a multi-compartment container for the screws.
(When working on a laptop this is the ONLY place I would advise using a magnetized screwdriver. Otherwise NO!)
There are different sized screws, and they also have different threads. It may be very easy to mix these up.
I also suggest you work on a table. If you have a carpet floor, do not swing your feet across it as you work.
(I feel required to post this, because there are those who might work on their bed, a couch, or directly on a carpet floor. These are high areas of Static electricity. Static will fry out a computers delicate hardware components in a flash! )
1.Computer off, remove all electrical sources. AC adapter, (Charger), and Battery.
2.Close the laptop. (Close the LCD screen down)
Turn the laptop upside down, front panel towards you.
Now you are going to remove the Switch Cover.
(Cover under the LCD screen, above the keyboard. Has the speakers, LED lights, Power On button, and so on)
Switch Cover Removal:
Look down in the battery compartment. With the battery removed you will now see three Philips head screws. One on each side. One in the middle.
Remove them.
Turn the laptop back over, open the LCD screen, and lay the screen back as far as it will go.
Lift the rear edge of the Switch Cover, and swing it forward until it rests on the keyboard. (The rear edge of the Switch Cover is next to the LCD screen)
[CAUTION!
Use finesse when lifting the Switch Cover, and resting it on the keyboard. There is a Small flat ribbon cable connected to the Switch Cover. You can only move the cover so far]
Notice that the small flat ribbon cable ends in a white connector towards you. This is a ZIF connector. (Zero Insertion Force) The flat ribbon cable is the LED light cable.
The ZIF connector is composed of two pieces. Think of a small rectangular box within a larger rectangular box.
The smaller inner rectangular box has a lip on it. This keeps it from going down through the larger box.
There is also a lip on the bottom of the smaller box, which keeps it from coming all the way out.
The smaller box is lifted by the top lip, or flange, to release the flat cable.
Again, it only lifts up so far.
It's hard to discern at first how the two box like parts separate from each other, your first time, hence this long explanation.
Looking close at this connector, you will see a thin parting line, approximately 1/16th of an inch down from the top.
Parting line where the two halves, or box like shapes separate.
Use your fingernails to hold the top flange, and the bottom half of the connector. Ease the connector apart. You may find placing your fingernails in the parting line helps, when you are separating the connector. Sometimes you have to gently rock the top half as you are pulling out.
Sometimes the connector top eases up with no problem. Sometimes it's stiff. Again, I advise using finesse.
The flat ribbon cable is composed of wires laid side by side, and installed into a flat ribbon like sheath of insulation. Each wire end has a conductive coating on it. When the ZIF connector is open, the flat cable slips right out.
[When installing, make sure you reinstall the flat ribbon cable in the same direction it came out. Be sure the ZIF connector is fully closed]
This particular ZIF connector may be different from the explanation above. Some do separate, and the cable is still connected to one side of the white ZIF connector.
Lay the Switch Cover aside.
3.Keyboard removal:
Close the laptop. Turn the laptop over, bottom facing you. Remove the Memory Module Compartment Door.
(Looking at the bottom of the laptop, this compartment door is in the middle. It is rectangular shaped, with the length going up, and down.
The battery compartment is above. The battery release latch button is to the upper left, of the Memory Module Compartment Door.
There are two Philips head screws. One in the upper left, and one in the upper right. (Upper is facing the battery compartment)
Remove them.
There are four screws to remove the keyboard.
Right below where the upper left screw was removed, for the memory compartment cover, is one of the screws that hold the keyboard on.
It's down in a small hole. (Below, in the statement, 'Below the upper screw that was removed', means facing you)
To the right of the memory compartment door opening is another keyboard screw. It's on the outside of the opening, down in a small hole. (Right above an air vent)
There are two more screws down in the battery compartment.
Now turn the laptop back over carefully. Open the LCD screen, lay it back as far as possible.
Lift the rear of the keyboard up to a 45 degree angle, towards you. (Rear of the keyboard is the edge towards the LCD screen. The keyboard will only lift so far due to a flat ribbon cable connected to it)
Slide the keyboard towards the LCD screen carefully. There are two tabs you are sliding out of the body of the laptop. (Top Cover)
These two tabs are on the keyboard edge facing you.
Once the tabs are clear of the slots in the Top Cover, bring the keyboard to a level position, and bring it back towards you. (It will only go so far. Flat ribbon cable!)
Lay the keyboard down on the Palm Rest.
Release the ZIF connector to which the keyboard flat ribbon cable is connected, and remove the keyboard cable from the System Board.
(Motherboard)
Reverse these steps to install the new keyboard.
In case I haven't explained these steps clear enough, come back, and let me know.
Thank you for using FixYa.
Nov 24, 2009 | HP Computers & Internet
I have a toshiba a55-s106 that displays a black screen with password in the upper left corner....any suggestions for resetting the password or overriding it?
open lcd panel you'll gonna see a small rectangular circuit (INVERTER)with two bus connectors one coming from mainboard an dthe other goes to lcd. It's always the culprit rather than the CCFL.
Jul 21, 2009 | Computers & Internet
Small rectangular b/w blocks on screen, low frequency whine.
check for filter(capacitor) problem in the video portion of the tv, and control could be dirt or finger contamination inside the remote.
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Motor lopes and is rough
Sounds as if you have had work done before. If the head covers were off before, then its agood likelyhood the spring could of come right out of someones pocket as they working on it. Things can slide down into the journel through the oil ports. You would be surprised to find just how many thing I have found from mechanics working on my engines of the past. Small washers and even small bolts can fall into the pan. This is why there is a pan in the first place to catch stuff. But if the engine has never been opened, then we are talking a whole other story. small smog values have small springs in them. One of these could of come apart and fall into oil passages. Some are large enough to pass small parts. If your engins is running rough its a good bet that one of the smog controllers came apart. Check egr value, its small enough to be suspected. It has a small spring inside of it. New ones are under 12.00 bucks. So I'd look there first.
Nov 24, 2008 | 2000 Ford Ranger SuperCab
Samsung SGH-A877 Impression Cell Phone Logo
189 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
