Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
''ariens 21'' self going -or need mix petrol and oil?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
You shouldnt need a petrol oil mix in the tank on a lawn mower
Posted on Jul 31, 2010
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
I need to know what type of oil to add to my ariens a173k22 lawn mower
Hi, if it has a Briggs and Stratton engine you need sae 30 engine oil. Regards Phil.
Apr 30, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
I have bougt an old Ariens RT 254 and wonder if I shall use petrol with oil or not.
I can't find anything on an RT 254, but if you meant RT 524, that is a rear tine tiller with a 5 horsepower gasoline (petrol) engine. That engine should not require you to add oil to the petrol. You can purchase a generic service manual which does includeyour tiller here if you like.
Or, just look for a crankcase oil drain plug which sticks out the side of the very base of the engine, and a fill plug, which is angled and higher up and usually plugged with a screw-in plastic plug. Take that plastic plug out and check the oil - in fact, if it's an old machine, I recommend you drain the oil (using the lower plug) and refill it (until it is at the level of the upper plug). In any case, this confirms you don't need to add oil to the petrol. Happy tilling! Please rate my solution if helpful, thanks.
Aug 15, 2010 | Ariens Garden
What type of petrol and oil to use for a sabre 3350 chain saw
The best thing to do is see if your Mom has the operators manual. If not, the best thing I can do is guess. Most chainsaws are two cycle. This means that fuel and oil has to be mixed. There is a formula that you can find on line depending on what ratio is needed. The other chamber that says oil on it is the tank for the Bar Oil. That is the oil that lubricates the bar and chain as the machine is running. You should get some oil that is formulated just for bar lube. Do mix fuel and oil, do put in bar oil...Good luck...Lee
Aug 31, 2009 | Garden
My Ariens 21 walk behind mower has lost its drive.
YES ! Probably the drive belt.
Jul 05, 2009 | Garden
How to pre-mix 2-stroke
the recommended mix is 40:1. So for 5 liters of fuel you're looking at 4.2 ounces of oil.
May 27, 2009 | Peg Perego Vespa Scooter
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
152 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
