Change the flasher unit, it's a cylinder type object, either blue or silver in color, usually in the fuse box, just pull it out and push in like a fuse.
The emergency flasher is the same shape, so don't cunfuse that with the turn flasher. To get the right one, turn on the 4 ways, put your finger on both of them, and whichever one you don't feel clicking is the turn signal flasher.
If you check the bulbs, OK, and change the fuses and the "flashers", its possible that you have a wire problem or your turn signal switch are bad. If its the last option, you just solve it with replacement.
Good luck.
SOURCE: No left turn signal
CHECK ALL BULBS, SOME HAVE A SLIGHT DARK SPOT ON THE BULB AND IS BAD AND FLASHER COULD ALSO BE BAD. CHECK THE FUSES TOO.
SOURCE: 2004 Grand Prix turning Signal lights wont work.
YOU HAVE TO REPLACE THE TURN SIGNAL SWITCH.BECAUSE WHEN IT GOES OUT.SOME TIMES YOUR DIMMER SWITCH STOP WORKING.IF YOU GOING TO FIX IT YOUR SELF BESURE TO.DISARM AIR BAGS FIRST.
