Removing outer casing
Can't work out how to do it
  • Thomas Christopher
    Thomas Christopher May 11, 2010
    What make and model computer?
    Genius:
  • 1,601 Answers
Thank you for rating this solution.
Posted on May 24, 2008
Its ok i've sorted it thanks everyone
Posted on Mar 31, 2008
How do I remove outer casing of my p210r32 air conditioner
remove screws from panel , it mar require tamper resistant tool kit .
Nov 13, 2014 | Soleus 10,000-BTU Portable Air Conditioner...
Will not drain
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Nov 11, 2009 | Whirlpool Washing Machines
Maytag Preforma washing machine won't drain water
Good luck !
Sep 12, 2009 | Washing Machines
If it is a desktop, there should be two thumbscrews in the back. Remove them and slide the side off.
If it is a laptop, then the RAM is probably underneath a cover plate on the bottom of the computer. Remove the screw and the cover should pop open.
Jan 13, 2009 | Computers & Internet
Change a stator
First secure the bike on a lift. disconnect battery.remove standard footpeg.Remove standard shifter. Remove all allen head bolts from outer primary cover. Some bolts are longer so keep track of where they go.Two bolts on the primary inspection cover also hold the outer to the inner primary case, so remove the cover.Now remove the outer primary case.The clutch,primary chain,adjuster, and compensating sprocket must be reoved as a single unit.Once you have done this take a rag and grasp the rotor and slide it off of the main engine shaft.Unplug the stator and remove the set screws holding it in place.Reverse procedure to install new stator.
Nov 20, 2008 | 2003 Harley Davidson FXD Dyna Super Glide
Change a stator
Nov 10, 2008 | Harley Davidson FXDI Dyna Super Glide...
Removal of outer casing
Dell has a good guide with images here.
Apr 28, 2008 | Dell Dimension 3000 PC Desktop
DJ Ditty Battery?
Battery is not replaceable on this unit. Removing the outer casing will just cause components to fall out - you will end up destroying the player.
Oct 30, 2007 | Dell DJ Ditty MP3 Player
SPin CYcle Noise
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump. Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then try to remove the clothing through the port.
Apr 16, 2007 | Kenmore 42722 Top Load Washer
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
