The washer fills, but won't run or agitate
The washer fills but won't run or agitate.
  • 5,911 Answers
If this is a Kenmore TOP LOADER, the most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back with your MODEL NUMBER and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on May 08, 2010
Kenmore washer model #111092581200 won't stop filling and won't agitate
Please recheck that model number. It is coming up as a microwave.
Oct 31, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
