Question about Intel D101GGC Motherboard
I have d101ggc motherbord with pentium(R)D cpu 2.66GHz 1GB of ram and 80GB pata hdd can my motherboard support 500gb sata hdd???
  • Anshul Sharma May 08, 2010
    how much sata hdd does d101ggc motherboard support??
    President:
  • 2,666 Answers
No reason why not.
Posted on May 08, 2010
  • 59 Answers
No your motherboard doesn't support 500 GB sata hard disk
How much HDD (GB) does Intel D101ggc support ? I have upgraded my HDD from 80GB PATA to 500GB SATA(with out any jumper). MB- Intel d101ggc, P4 Processor. RAM 1GB, But after that my PC got slow. It takes...
You then must have re-installed your XP, and if no other Hardware configuration changed then it sounds as if you do not have all the necessary drivers reloaded.
Check your Device manager if there are any notifications and update all drivers.
Then look at this and follow these steps to also identify where your issues may be.:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/sag_mpmonperf_15.mspx?mfr=true
Sep 12, 2012 | Intel D101GGC Motherboard
Sir my inspiron laptop b130, intel pentium processor 1.70 mhz 598 mhz, it is suitable for upgration r not? ram 1gb. 40 gb hard disk.? I need 2 gb ram and 500gb usb hard disk for oracle applications...
Max RAM for that system is 2GB
http://www.crucial.com/store/listparts.aspx?model=Inspiron%20B130&Cat=RAM
The question is whether there are 500GB hdds for that system. The largest PATA HDD I found was 320 GB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4600076&CatId=2675
and there is no guarantee the BIOS will recognise a HDD that large as PATA HDDs require BIOS support for the drive size where SATA HDDs will pretty much work.
My recommendation is to retire this system and BUY a new one.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=631874&csid=_23
Sep 10, 2011 | Dell Inspiron B130 Notebook
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel D101GGC Motherboard Logo
232 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
