Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have to push on the lid to get the washer to start every time.
  • 5,911 Answers
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on May 08, 2010
Whirlpool washer when top lid is open washer start comming on before that it didnt do that any tip whats going on with washer
There is a small hole that when pushed in will make the washer think the lid is closed. See if something is obstructing that or if it is pushed in.
Mar 31, 2017 | Whirlpool Washing Machines
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Washer wont operate even with lid shut. I have to push on lid until it starts.
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
Sep 09, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Whirlpool High Capacity washer, start cycle , it fills with water then no agitation, and no spinning.
next time send the model number,open the lid,look on the right side and there should be a hole in the top,that's the lid switch,it's used so the washer won't run if the lid is open for safety reasons,set it to spin and with a screw driver push down on the plastic piece in the hole,if nothing happens push in and release,do this a few times,if you don't hear a clicking sound when you push up and down the switch is bad or close the lid and open it an inch,close it and open it a few times,no clicking sound the switch is bad.
Jun 12, 2011 | Whirlpool 3.2 cu. ft. Washer
Washer starts to fill whith water then stops .
next time send the model number so i can look up you machine,i can give you the part number and price.if it's a top load washer set the timer on spin,open the lid and with a screw driver push down on the lid switch,you'll see a hole in the top of the frame and a strike on the lid the strike pushes down on the lid switch and sends power to the washer,the factory doesn't want the washer to run if the lid is opened,if it starts to spin then you have a bad lid switch,the switch could be totally broken so if it doesn't run the easiest way to check the switch is to push down and the up on the switch if it makes a clicking sound the switch is good,no clicking the switch is bad.this is a common problem,let me know if this is it.if it isn't the problem send the model number.thanks.
Apr 03, 2011 | Kenmore Washing Machines
Top Loader stopped during spin cycle and now won't work
The lid switch cuts off power to the washer and will cause the washer to stop and not to start at all when it fails or when the lid switch strike breaks. Check the lid switch strike located on the middle right side of the lid. Replace the lids witch strike if it is broken with part number 3950298.
Push and hold the lid switch, using a screwdriver, through the hole on the right side recess of the top cover and start the washer. The lid switch actually clicks when activated.
Check the continuity of the lid switch when activated if the washer still doesn't start when the lid switch is pushed and held. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the screws at the front bottom corners of the console then slightly pull the console forward to clear the console tabs from the slots on the cabinet, and then flip the console to the rear of the washer.
Disconnect the wiring harness connecting the timer to the lid switch wiring harness connector on the cabinet then using an ohmmeter, check the continuity of the lid switch while it is being pushed. Set the ohmmeter to XR1 then touch the test leads to the right and left terminals of the lid switch connector. Replace the lid switch when the resistance reads open.
Apr 06, 2010 | Washing Machines
Troubleshooting Whirlpool Push to Start Mechanism for Washer
What kind of whirlpool do you have? is it a top loader or a frontloader. If it is a top loader is there water entering the washer? does it not agetate? Does it not Spin. If it does not wash or spin it is a possible bad lid switch close the lid. Do you hear a click? If you have no CLICK sound you have a bad lid switch.
Jan 22, 2009 | Whirlpool Push to Start Mechanism for...
WASHER FILLS BUT THEN WON'T START. WILL LIFT THE LIFT AND CLOSE SEVERAL TIMES AND THEN WILL START. NOW DOESN'T START AT ALL. IS THIS THE SWITCH ON THE DOOR, SHOWING IT ISN'T CLOSED SO IT WON'T START?
must be a whirpool or kenmore shut lid try pressing down on left rear corner be sure lid hinge screws are tight then raise lid on left corner under top out of sight you will feel small lever push toward back of washer slightly and then try again also if lid center has popped down push up slightly in center till lid pops back up sen it happen once where washer would not spin
Jun 17, 2008 | Washing Machines
The lid will not lock.
you cant bypass this switch by pushing w/ screwdriver. its a magnetic reed switch open the top deck (3 screws behind the console) inside should be a tech ref sheet quite helpful trouble shoooter in ther
Jan 13, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
