Question about Hotpoint Ultima WF865 Front Load Washer
Error code F-05. How to repair? - Hotpoint Ultima WF865 Front Load Washer
I get an error 05 on my SINGER Futura xl-550....i have it set up to embroider and when i turn the machine on I get the error and the arm does not move
You need to find out what error 05 means. Usually, you will find that information in the troubleshooting section of the owner's manual. If not, you can search for:
Make Model error code 05
You may need to contact Singer Support if you can't locate an error code list.
Feb 28, 2018 | Singer Sewing Machines
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Corrective Action
Apr 11, 2011 | Precor 933 Premium Series Treadmill
What is code P0420?
P0420 is Catalyst System Efficiency Below Threshold (Bank #1)
Trouble area:
- gas leakage on exhaust system
- oxygen sensor
- three-way cat. converter
http://manual.shulsmann.com/Repair%20Manual/05/200o8c05/dtcc4000.pdf (see page 2)
http://manual.shulsmann.com/Repair%20Manual/05/200o8c05/cip0420.pdf
It sounds like one of your catalytic converters doesn't appear to be working up to par if you're getting this error code.
Oct 17, 2010 | 2003 Toyota Matrix
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
Receiving and Error Code 5
Error 05 points to a problem with one or both reel motors. Not field-repairable for a non-technician.
Mar 25, 2009 | Sony PVW-2800 VCR
Hotpoint Ultima WF865 Front Load Washer Logo
524 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
