Question about Garden
Charged battery. put on parking brake but when I go to start it the red park brake light goes on. The engine never turns over.
  • Anonymous Mar 29, 2014
    will not start.red light showing park brake not on when it is.
  • 198 Answers
There is a lock-out switch connected to the parking brake. see if it is stuck or if need be disconnect and jump the wires.
Posted on May 10, 2010
Put new starter on still wont start fan isnt even turning what else could it be?cylinoids are good too.
Will the starter motor crank the engine? If not, check the starter motor wiring circuits. Usually two voltage circuits at starter motor. One comes from the battery, hot all the time. The other goes hot with key in the crank position. The starter motor usually grounds through the engine block. Any testing at starter motor, make sure tranny is in park or neutral and parking brake is set.
Make sure battery has a full charge and battery connections all good.
I need year--make--model?
Nov 29, 2017 | Cars & Trucks
After starting transmission won't move out of park
It sounds like if this is a car with the brake interlock, meaning the car will not shift from park unless the brake is pressed, there is a malfunction there, some are electronic and it may not be getting power to it especially if there are other warning lights on the dash. It would help if you could give more details, like which lights are on. Most cars with a mechanical interlock will have a cable you can adjust either at the brake cable or at the shifter.
Aug 02, 2016 | 2013 Ford Fiesta
Starting problem
1. Test battery (Should read 12.5-13v). If not charge or get tested, may need replacement.
2. If battery is good, take a pair of jumper cables, connect Black lead between (-) Negative side and the the block of the engine (often there are metal brackets, etc they make good connection points). Then connect the Red lead, between the the (+) Positive side of battery and JUST TAP the end to battery connection on the starter solenoid to see if engine turns over. CAUTION: Engine vehicle is in Park, parking brake set, and will not move before attempting this procedure.
2a. If this does not turn over engine, remove starter and have it tested at an auto parts store.
2b. If it does turn over there are two paths to further troubleshoot. (1) check battery cables. One way to do this is to turn the ignition key on, and attempt to start the car by the method described in 2.. BUT EXTRA CAUTION: Engine vehicle is in Park, parking brake set, and will not move before attempting this procedure. (2) if the truck did not start in (1), then you will have to wire trace the starting circuit checking all fuses, connections, etc. (local auto parts stores or often local library, carry Haynes Manuals that have wiring diagrams int the back)
Best of luck resolving this problem.
Dec 11, 2013 | 2002 Ford Ranger Regular Cab
1990 jetta parking brake release kills engine
Okay, so the car's engine is running, and you're in drive but it's not going? It sounds like your transmission needs service.----------------------------------------------------------------------------------------
OPEL KM TOOL
Mar 19, 2013 | 1990 Volkswagen Jetta
2006 Ford Expedition will not start this morning, battery checks 12 volts, will not do anything when turn key to start position
You can jump starter relay to see if starter will crank the engine. Pull the starter relay, use jumper wire between terminals 30 and 87, terminal 30 is hot all the time and there is a fuse, the starter motor should crank the engine. If you try that make sure tranny is in park or neutral and parking brake is set. Two voltage circuits at starter motor, one is hot all the time. The other goes hot when relay is energized. The starter motor grounds through engine block. Battery positive and negative connections are important.
Nov 18, 2017 | 2006 Ford Expedition
BOUGHT BRAND NEW BATTERY NOW CAR CUTS OFF AND IDLES REALLY LOW
WHEN YOU DISCONNECT THE BATTERY THE ENGINE MANAGEMENT SYSTEMS PCM LOSES IT MEMORY INCLUDING ENGINE IDLING.THE COMPUTER WILL HAVE TO RELEARN THE OPERATING VALUES. IF CAR DOES A LOT OF STALLING AT STOP LIGHTS AND STOP SIGNS. GO BY FORD DEALERSHIP LET THEM REPROGRAM THE PCM.PROBABLY CHARGE YOU $35.00 DOLLARS. TO REPROGRAM PCM.
Jul 04, 2011 | 2006 Ford Five Hundred
Why does the parking break light stay on in my 97 Olds Cutlas Supreme. I have checked the level of the break fluid and it is full. I did have new break lines put in last year. I did have to slam on my...
Apply the parking brake with the vehicle parked, engine turned off and transmission in Park. Release the parking brake completely, then apply it again, and ensure that it is fully released. Turn the ignition on, check to see if the Parking brake warning light is on. If it is NOT on, apply the parking brake and check to see if the warning light comes on. If the light come ON wihen the Parking brake is applied,.....fully release the parking brake and check if the warning light goes OFF. If it does NOT go off, then an adjustment is needed at the parking brake switch.
Jan 09, 2011 | 1992 Oldsmobile Cutlass Supreme
Parking Brake Fault light is coming on? I reset the battery and it keeps coming on. It starts with the "apply parking brake" light and then when you take off, it goes to a parking brake fault? Please...
This is a common fault often caused by low battery voltage, before you start taking expensive actions with the park brake modules etc get your battery checked for 100% efficiency.
Hope this helps, good luck.
May 26, 2010 | 2003 Jaguar S-Type
.1991 Ford Aerostar 4.0 Lt engine, auto tran', electrical short ?
turn every thing on in park if voltage drops change alt
Mar 03, 2010 | 1991 Ford Aerostar Extended
Parking light brake light will not go off after power is engaged
no the P light ans system will always be on unless you command a drive or N funtion since there is no 'park' in the drive train only a mechanical brake. when running/on, when you put in drive it should acknoledge drive and P should unlock. if not you have trouble and need the dealer
Sep 02, 2009 | 2003 Toyota Prius
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
