Question about Nokia 3110 Cellular Phone
My nokia 3110c is switched off again &again work for 3 minutes only help me
  • 91 Answers
If you have a memory cars remove it and restart your phone.It usually works.Now,back up your data in memory card and format it.Fill the memory card only to its half the space.Try working the phone after inserting the memory card.If the problem is still there, then,you have to stop using your memory card or reinstall phone firmware.
If you don't have a memory card then, delete all the messages( Inbox ,Sent item etc).Clear the phone memory(delete images,themes etc).You may backup these things before deleting.
Now restart the phone.
If the phone doesn't stay long enough to do these things then,connect to a computer and do it.
Posted on May 09, 2010
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
My nokia 3110c is blinking n switch off after the logo appear
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step. It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime.
Apr 19, 2011 | Nokia 3110 Cellular Phone
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
I use nokia 3110c with memory card for past 1 year.one day it got switched off. i switched on again. after 1 minute it again switched off.this happened again and again. i took the memory card out. It...
I could not say whether the problem comes from mmc or from the set because 3110c has very weak software So firstly scan the mmc with updated antivirus.Secondly. Flash the set . Thirdly contact nearest mobile repairing center .
Aug 11, 2010 | Nokia 3110 Cellular Phone
I m using nokia 3110c it automatically switch off and now wen i tried to on it. it starts blinking 2 to 3 times and then switch off again. please help me out to solve the problem
Remove ur sim, battery and mc... let it refresh and again put battery and sim alone... Press green button(call button) ,* and 3 simultaneously and switch on the mobile... make sure that while doing this the "Battery should be in charging"... later, format the memory card and use it... hope this works out well!! And maintain ur phone memory between 250-300 kb.... Al the best!!
Apr 23, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
method
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
How to format nokia 3110c
Hi i m Almadani, i have Nokia 3110c,
in 3 or 4 days when i change my sim or insert a memory card,
so when i on my mobile after few seconds the cell switch off then on every time i on my cell then switched off after few seconds,
when i on with out memory card then the cell work normaly,
so waht i do for that?
can i formate it?
if i want to formate, then how i to formate?
reply me.
thankyou
Sep 05, 2008 | Nokia 3110 Cellular Phone
Unlock security code for nokia3110c
Hi sir, i have nokia 3110c and i have forgot the security code which i had changed from default i.e 12345..and the new security code i had forgot...please help me out to unlock mine phone as if i have mine important contact numbers and data in dat phone pls help me out for this...
Jul 09, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 classic
Solution 4 Nokia 3110c Restart
If
method
4] Then you must restore Factory settings from the Settings Menu
6] Now
ur phone
9] Switch On
Feb 11, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
