Question about Nespresso Aeroccino Automatic Milk Frother
Milk burning on the base of the aeroccino
We have only had the aeroccino for 4 months. Every time we use it there is a tendency for the milk to burn on the base just beside the rotor 'pillar'.
If you do 2 milk warmings without a thorough wash and clean between - then the milk burns badly and it is difficult to remove the marks.
Is this us? or a faulty machine? or both!
By the way we love the aeorccino and the nespresso coffee machine!
SOURCE: the nespresso aeroccino will not turn on.
That happens to me every once in a while, but when I shift the machine on the power plate it will turn on again...I think it's something not lining up with the power plate....I don't know if this is the same, but it always seems to work with mine...I LOVE my machine, I've had it for about a year and a half and use it every morning.....
Posted on Aug 14, 2009
  • 21 Answers
SOURCE: nespresso aeroccino doesn't work after milk was
The company will tell you to turn upside down for 24 hours to reset. I did and this did not work, you may have gotten base wet, which can break machine. Try turning upside for aeroccino upside down for 24 hr. you do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck.
Posted on May 08, 2010
  • 21 Answers
SOURCE: My nespresso aeroccino machine seems either quirky
THEY SAY MILK MATTERS. SKIM OR LOW FAT BEST. ALSO MAKE SURE IT IS CLEAN, WHEN YOU ARE CLEANING IT, REMOVE THE FROTHER, TO BE SURE MILK DOES NOT STUCK IM COIL, WHICH CAN MAKE THE FROTHER, NOT MOVE AS QUICKLY AROUND.
  • 21 Answers
SOURCE: Nespresso Aeroccino milk scum hard to remove
I have used a baby bottle brush. It is not easy to clean, and the cooked milk does build up, and the scum build up will cause the frother not to move as fast compared to when it is clean.
  • 21 Answers
SOURCE: Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
Feb 18, 2012 | Nespresso Aeroccino Automatic Milk Frother
Tip
Nespresso Aeroccino Automatic Milk Frother Instructional Video
Click on the link below for the user guide for the Nespresso Aeroccino Automatic Milk Frother - http://www1.nespresso.com/precom/accessories/demo/aeroccino/index.php?lang=en
on Apr 27, 2011 | Nespresso Aeroccino Automatic Milk Frother
The milk doesnt heat up or froth but the button flashes red
We had the same problem with burn marks on the bottom and flashing red light etc. Now we just rinse the container out with cold water each time we use it - do not dry, just leave it wet and then add your milk. Heats up perfectly each time. The water lubricates the base of the container, preventing burning. Nice hot coffee every time now. Hope this works for you too!
Apr 20, 2011 | Nespresso Aeroccino Automatic Milk Frother
Have same problem with my Citiz & Milk, I wash out the aerocinno after each use and I have cleaned it out again snnce but still cna't get it to heat the milk. The machine is only a couple of months...
The last couple of times I have used my milk frother on my Nespresso Magimix has overflowed creating a mess. Its almost as though the pressure builds up and forces the milk to overflow. Any ideas?
Oct 18, 2010 | Nespresso Aeroccino Automatic Milk Frother
Burnt Milk at Bottom of Aeroccino
Try this - make a paste from bicarbonate of soda and water and let it
sit in the bottom of the frother for ten minutes or so. Then use a sponge
to clean off the milk stain and rinse and dry thoroughly. To prevent it from
recurring, rinse and dry the inside after each use and don't get the base
of the frother wet.
Jul 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
Nespresso aeroccino doesn't work after milk was overflowing. Is there some kind of security which can be resetted?
Apr 12, 2010 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
I have an Nespresso Aeroccino that will not make froth
Sorry, but it looks as though you have the classic Aeroccino-problem. Nespresso states that leaving the Aeroccino on its base while it is plugged-in to the wall, will cause it to short-circuit (because there is no off-switch on the base, it is continually feeding full power to the frother), and the result is that it makes only warm milk. Replacement is the only solution...I hope you are still under warranty.
Jul 28, 2008 | Nespresso Aeroccino Automatic Milk Frother
Not making froth
Had the same problem, but called Nespresso. Their tech suggested the following: 1) always leave off the base - will stay on even if button not pressed 2) invert the Aerocinno for 24-48 hours to "reset" the thermostat in the device. I began leaving the base plugged in, but immediately after using and cleaning (don't get ANY water in the bottom of the machine!), I invert the Aeroccino and leave it that way. My machine began making great froth with any tyoe of milk, and continues to do so a month later -
Sounded crazy to me initially, but it works.....Never returned the device, and no need to do so now - Good luck!
Jan 05, 2008 | Nespresso Aeroccino Automatic Milk Frother
On/off problems
Found out if you just leave it for 30 seconds after turning the power on but before activating it works fine.
Dec 16, 2007 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
381 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
