Question about Paxar Pathfinder Ultra (P/N M16035-LPRF) (m16035lprf) Portable Terminal
Paxar pathfinder does not feed labels running diagnostics to calibrate the printer i get the message correct error 704
    Novelist:
  • 113 Answers
704 on this printer means
Printer has not sensed a supply mark within the specified number of inches.
Since this is a black mark printer, there should be black squares at the bottom of the liner that passes through the printer. If you have no black squares, then you're using the wrong supplies.
The plastic that holds the supplies in place should spring open if this is a 6032 or 6037. Some of the 6032 and 6037 printers have a supply lock that is a little gray tab at the base of the cavity where the supplies are held in place, but before they angle up past the supply sensor and over the rubbery roller. It is possible that this is locked in the wrong width for your supply size. If it is, try folding it out away from the supply roll so that the supply holder can move freely, judge the width of your supplies and use one of the 3 fixed positions for locking the supply holder in place. Your supplies should fit snugly either way.
If your supplies are loaded correctly, go into diagnostics and go through the paper registration to try and calibrate your supplies. If the printer passes, you should be good to go. If it fails, call the support line from monarch.com, and a repair tech can walk you through the proper setup by having a quick 5 minute call.
Good luck.
Posted on May 23, 2008
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Barcode printer type: TOSHIBA SX4 sensor setting for thermal transfer / transmissive error msg paper jam. how to see the sensor?
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
Feb 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
What is error #704
704 is a supply error. You get a 704 either because the supply sensor is broken or is out of calibration, or because you have your supply type on the printer set for something different than what you're printing on.
If the rubber platen roller that turns and feeds your supplies through your printer is too slick, or has a roller wrapped around it - that can cause a 704 error too.
If you have a black line on the back of your supplies you should be set for "black mark". If you have labels that have a space between them, you should be set for "die cut".
Jan 19, 2011 | Monarch Paxar 9825 Printer
Error 704 Check Supply
Check to see that you have the correct supply selected under "supply type". Are you running black mark supplies or die cut supplies? If the supply type selected doesn't match your actual supply type, you'll get a 704 error. It's also possible that the black supply sensor could be broken, or your platen roller (large black roller) needs to be cleaned. Clean it with alcohol.
May 14, 2010 | Paxar Monarch 9825 Thermal Label Printer
Check your supply type in the "Supply" menu. You either have the wrong supply type set or the supply sensor is broken...
Mar 24, 2010 | Paxar Monarch 9825 Thermal Label Printer
Printer does not print in correct place after calibration, stops and says paper error
Sounds like the printer is not getting the proper calibration on the label being used. After putting printer in pause and pressing calibrate button, a good calibration is indicated by the labels feeding, a slight hesitation, and the feeding a couple of more labels at a faster speed. If the labels just feed and then stop, that is not a good calibration. Then you have to make sure the top and bottom media sensor are properly aligned.
Mar 01, 2010 | Zebra 110Xi III Plus Thermal Printer
An error #704 message keeps coming up and telling me to check supply, but as far as i can tell everything is loaded correctly. any ideas?
Check your supply settings. Die cut or black mark?
It's also possible you have a bad/broken/dirty supply sensor. The supply sensor is black and is located on the adjustable supply guides. These guides are what you first feed the supplies thru as they come off of the roll. Opposite of the small black latch you move to adjust for supply width.
Mar 01, 2009 | Monarch Paxar? 9855 Label Printer
Paxar 636 diagnostic test 2 error
paxar 636 diagnostic test 2. i've encounter this problem last 2004. the diagnostic test stops at diagnostic 2. what we did is that we've checked the mother board and the printhead board. basically those boards are the main problem when you encounter that error (diagnostic test 2 error ). what we did is that we changed the mother board as well as the printhead board.
Aug 02, 2008 | Avery DesignPro Deluxe CD-ROM...
Error code
HI
RESET TO FACTORY SETTINGS AND TRY AGAIN.
Mar 24, 2008 | Paxar Monarch 9825 Thermal Label Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Paxar Pathfinder Ultra (P/N M16035-LPRF) (m16035lprf) Portable Terminal Logo
182 people viewed this question
Top Paxar Computers & Internet Experts
David Payne
David Payne
Are you a Paxar Computer and Internet Expert? Answer questions, earn points and help others
