Question about Garden
I have a Simplicity Riding Mower - 17 Hydro and the engine has blown twice - the second time yesterday - what are my options for fixing the engine - last time I completely replaced the engine - can the engine be fixed without a complete replace?
    Scholar:
  • 110 Answers
Depends why it blew! Given the right oil, and changed regularly, the engine should out-last the mower.
If the engine is a Briggs, you can fix anything short of a rod through the crankcase. If it's any other make, a replacement will be cheaper.
Check that the replaced (or repaired) engine is not over-speeding.
Posted on May 08, 2010
How do you fix slipping transaxle on yth 21k46 Husqvarna riding mower
Hydro units are not adjustable, check the belt from engine to hydro pulley is tight,check the disc brake is not bindind, this is on the side of the hyro unit and is adjustable,if all is good then the hydro unit itself is suspect.
Jul 25, 2017 | Husqvarna Garden
I have 2005 simplicity 21hp citation series zero turn mower and hydraulic oil is leaking out the bottom of the left hydraulic pump.What is the reason for this and how can I fix it?
Anon, could be a line,fitting,pump seal,gasket,etc. Have a look and wipe down clean and then locate leak location and decide whether you want to tackle the job or have a tech. do it. If it is the pump you can google search to see if parts(rebuild kit) available or you can search for replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ZERO TURN MOWER REPAIR how to replace the pumps and wheel motors
Hydro Gear rebuild wmv
Repairing Hydro Pump
Apr 25, 2016 | Garden
Simplicity. How do I test the interlock module?
snapper mower:interlock module - how test?
www.homeownershub.com > Home Repair
May 28, 2005 - 1 post - ‎1 author Snapper 1438H Hydro, rear-engine riding mower. Thing yesterday just quit. ... Next item up the line is the INTERLOCK MODULE... All the safety ..
Sep 05, 2015 | Garden
Simplicity regency 12 hydro sucking oil into carburetor. what could be the problem?
blown head gasket... it pressurizes the engine causing oil to blow out...
or
oil is WAY to full
should of mentioned the engine brand because simplicity doesn't make it !!!
Oct 18, 2014 | Simplicity 2691011 - Regent 42" 21HP Lawn...
Mower deck slows and stops when I turn my Simplicity riding mower to the left,
HI,
The simplicity has a a two point mounting system for the deck. It attaches to the front axle which has two runners that go to the front axle's rear support bracket.
Closely check the runners near where the pins that hold the mower deck. They are known for cracking and breakage. Secondly, closely check the decks metal center support bracket, it bolts to the center of the deck and supports the idler pulleys as well as the deck alignment and mounting. Those, too, are known to crack near the front just behind the front pulley.
Aug 25, 2012 | Garden
Belt size for 616 deutz allis riding mower ,deck & drive
most wear parts numbers are on the bottom side of the hood.
Jul 29, 2012 | Garden
Gas somehow is getting into oil reservoir. Twice now. Initially thought it was operator error. After second time, know it is the mower. Craftsman 17 hp 24 inch riding.
I would check the carburetor float to ensure that it stops gas flow once it is full. It is possible that the float is stuck and gas is getting to the top of the engine and getting past the rings.
Gary
Jun 29, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
