Question about Garden
Our troy built mower stopped moving the other day while mowing. The mower was still running and the blads were still turning and cutting but it would not move forward or reverse. I've checked the drive belts and they all seam to be fine.
2 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: my troy built pony mower
Sounds as if you have broke something in the transmission if all your belts are in good shape.
Jim
Posted on Jul 28, 2011
My riding mower stops moving forward after 30 minutes of cutting it starts right up the blades engage properly and cuts great it will just stop moving
Check under the seat under the battery box there you should find the drive pulleys for the rear end the belt could be worn out and turned inside out causing it to slip or stop pulling once it heats up mine was installed inside out from Lowes when I purchased the mower causing me to replace the belt hope this helps
Sep 16, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
While mowing with a 21 inch selfpropelled mower i hit a large bolder and the sound and power seemed to drop in half, but still runs smooth any thoughts?
Mower blade might be bent, that would cause it to run out of balance and it would slow down the speed of the engine.
Jul 12, 2014 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
My Briggs and Stratton powered (17.5hp Intek model 311777) Troy Bilt riding mower idled down slowly and died. It was a very hot day after about an hour of mowing. I don't appear to be getting an
Hi, armature is for spark and you stator is only for charging the battery. Check for spark again after disconnecting the single small wire from the armature incase its a safety switch issue, regards Phil.
Jun 06, 2012 | Garden
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
