Question about Kenmore 53552 / 53554 / 53559
Ice maker # S10626636 water level adjustment
Water overfills ice maker and runs over making one big blob of ice. I know there is an adjustment screw on the front under the cover but don't know where.........HELP>>>>>>>>>>>>>>
    Novelist:
  • 184 Answers
IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
Posted on Mar 27, 2008
Wr30x10044 ice maker - how to adjust water level
There is a plastic circle tab on the side of the ice maker that covers a screw turn it to the left. But I doubt it your ice maker I'm pretty sure it's your water valve that is causing your overfilling
Feb 15, 2015 | Refrigerators
My ice freezes as a block when dispensed into ice tray
There are water level adjustment screws behind the plastic cover of the ice maker to adjust the water level when it refills after dumping a tray of ice. When there is to high of a water level it spills over onto the cubes freezing them into a big block. Try to adjust the level of water. There is a arrow which tells you which way to turn the screw to get a smaller fill fixing the problem.
May 04, 2014 | Refrigerators
Too much water dispenses to ice maker
The adjustment is going to be located on the ice maker its self, on the big white part. It's more than likely going to be concealed by a plastic tab. Keep in mind that the water valve could be sticking to. Adjusting the water fill amount could result in no ice or a flooded fridge. Keep that in mind
May 11, 2012 | GE GSL22JFXLB (22 cu ft) Side by Side...
My U-Line CO2075FS ice maker seems to over fill and drip water into the ice cube storage drawer. How do I adjust the water flow or fill level limit?
If your water is overfilling then you probably need a faceplate for your icemaker. If you remove the cover on your icemaker(pry on the corners and pull @ same time) You will see a screw with a spring on it. That adjust the water flow. If you tighten you decrease the water. Make sure the gears are not corrioded. If it is. Replace the plate with the gears on it.
Oct 08, 2009 | U-Line Icemaker
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Sep 16, 2007 | Samsung RS2534 Side by Side Refrigerator
Kenmore 53552 / 53554 / 53559 Logo
396 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
