Question about Sony Playstation 3 (PS3) Console
There is a video but no audio in HDMI
Kindly help
  • Sony Expert
  • 311 Answers
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
Posted on May 08, 2010
NO sound form HDMI out
Most likely switched off. Look up the settings for it.
Nov 08, 2015 | Audio Players & Recorders
How connect an LCD tv to hi fi when dvd player is connected in hdmi to THE LCD TV?
you need to see if you have audio out on the tv, if so! you need to go from audio out on tv to input on your home stereo! everything played on tv will work through home stereo! if no sound, you have to go to menu on tv and into sound and change TV's output from internal speakers to external output! hope this helps!
Jun 12, 2017 | Akai LCT2715 27 in. LCD Television
Hp plasma ID5226N can get external audio input when in HDMI 2. I have a DVI to HDMI cable from my computer to TV, & manual says to hook the audio to the input jacks, but no sound comes out. I can use...
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Jun 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
No audio
if possible use the hdmi as a video feed and non-hdmi as a audio feed i am not sure if hdmi even carrys sound.45687d7.jpg
Jun 27, 2009 | Microsoft Xbox 360 Console
HELP WITH CNECTION
Only if you've got an HDMI output on your computer. Some computers with higher quality video cards, or just newer ones will have a DVI output for a monitor. You can get a DVI to HDMI cable that will then be able to connect the two.
As others have said, if you have a video card with DVI output, you can get the video to the TV using a DVI to HDMI cable.
But no one mentioned anything about audio. DVI can not carry audio, so you'll need to send audio from the computer to the TV (or receiver). Some TVs have audio inputs associated to one (or more) HDMI ports for use with devices that have DVI, but not HDMI. My Sharp LCD has two HDMI ports, one with separate audio inputs, one without.
Sep 27, 2008 | Computers & Internet
No audio or video with HDMI connedction
AT THE START OF THE SET UP MENU CLICK ON IN/OUT ASSIGN.THEN MONITOR OUT APPERS,THEN HDMI NO,FLICK THIS TO ON.IFF YOU GET PICTURE AND NO SOUND GO TO THE HARDWARE SET UP AND DOWN TO HDMI AND SWITCH AUDIO OFF.
HOPE THIS HELPS.
May 05, 2008 | Onkyo TX-SR605 Receiver
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
