Question about Char-Broil Charcoal Water Smoker 4654301
How to use
We loss the manuel..How do we use the H2O charbroil water smoker
I have a char-broil smoker. It's not electric, though. It's a charcoal outdoor grill. I need to know how to use it. Got it at a garage sale and forgot the instructions the seller gave me. Any...
I'm not sure this is the same model you have, but it's the only one Charbroil now makes. In any case, most vertical charcoal smokers work the same way.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/06701289%20assembly%20manual.pdf
I hope this helps you. Enjoy your smoker and thanks for choosing FixYa.
Aug 16, 2011 | Char-Broil Electric H2O Smoker
I just got a Char-Broil H2O Smoker from a friend. I do not have a manual to tell me how to operate it. Also one pan is for charcoal and one pan is for water. Which pan is for which thing? One pan is solid...
Debbie, since you didn't have an Owner's Manual with your smoker. Rather than me go thru a lengthy process of explaining all there is to know and how to use the H2o Smoker.
Here's a link to the Owner's Manual, that you can download and print for future reference.
Hope this helped you and enjoy your smoker.
Jun 19, 2011 | Char-Broil Charcoal Water Smoker 4654301
Trying to figure out how to use my charbroil h2o electric smoker without a manual? can you help?
You can get a free PDF manual at Char-Broil,com and you can also talk to other users at http://sizzleonthegrill.com/user-forums/ and I bet you get lot's of help there.
Jun 24, 2010 | Char-Broil Electric H2O Smoker
I need a manual for a Char-Broil H20 Smoker. Is
Go to this link and you should see a download for your smoker on the right hand side of the screen.
http://www.charbroil.com/ProductSupport/06701311/Electric-H2O-Smoker.aspx
Hope this helps.
Jun 21, 2010 | Char-Broil Deluxe Charcoal H2O Smoker
Have this smoker but really dont no how to use it where do i put the wood chips do i put them in the pan with the water our do i put them on the plate please help me with this
Page 3 on this link shows the wood tray and explains the water tray. Wood chips are soaked to make them last. They will still go pretty fast but you can add more. Soak the chips or chunks overnight.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/06701311_assembly%20manual.pdf
Jun 10, 2010 | Char-Broil Electric H2O Smoker
How do i prepare wood chips for my charbroiler h2o electric smoker?
To prepare wood chips, soak in water for at least 30 minutes or more. Soaking will cause chips to smoke releasing the flavor of chips.
Jan 19, 2010 | Grilling
Need electric plug for smoker
go to home depot and get the replacement element for the brinkmann gourmet smoker. costs $29.95. the replacement parts from charbroil (thermostat and element) will cost about $60.00. just remove the elemnt, replace it with the brinkmann and you're back in business.
May 10, 2008 | Char-Broil Electric H2O Smoker
Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Apr 28, 2008 | Char-Broil Electric H2O Smoker
Char-Broil Charcoal Water Smoker 4654301 Logo
462 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
