Question about Ruud UAKA030 Air Conditioner
We need an owners manual.
RUUD UAKA-030JAZ
    President:
  • 1,515 Answers
Hi, looks like you have a 21/2 ton Ruud split system by the numbers. Let me look this up and see if I can find a manual for this unit and send you a link to down load it. Give me sometime please. Be back soon.
Shastalaker7
Posted on May 08, 2010
  • Robert Horton
    Robert Horton May 08, 2010
    bestbuyheatingandairconditioning.com Hi, I have searched the Internet for both Ruud and Rheem units for a munual with not a lot of luck. I was able to come up with this link that may be of some help as they deal with both of these units and that model. You should be able to get some info from them or some direction on where to go. What seems to be the problem with you're system, or do you have one? I can be of help if you do. Let me know please. Best to you, Sincerely,
    Shastalaker7
    PS This is not the electronics/entertainment Best Buy. :)
  • Rhonda Kelly May 20, 2013
    my a/c won't come on. The unit in the attic makes a really light humming noise but won't come on.
Where is a breakdown of parts for ruud air conditioner haka-030jaz
Call the local Ruud distributor. They have parts breakdown.
Mar 27, 2016 | Ruud Heating & Cooling
Where can I purchase a run start capacitor for a RUUD air conditioner model # UAKA-030JAZ
Most big box stores do not carry these type of parts.You are supposed to be a licensed contractor to buy at a heating & cooling supply company. Not knowing were you live I can not recommend a supplier. I am in the Cleveland Ohio area. If you can not find it locally I can ship it for you.
Jul 04, 2014 | Ruud UAKA030 Air Conditioner
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
Freezing pipes and water dripping on to motherboard of the heater in a Ruud UAKA-030JAZ system. Help?
More than likely, the system is low on refrigerant and the copper line-set is freezing up and water is dripping onto the board in the furnace (and other things) because it is an upflow system with the evaporator coil on top. Other things to check would be:
1. Dirty/clogged filters in the return air system.
2. Fan motor not working inside furnace. (The Blower)
3. Coil dirty/clogged which could be checked by the amount of airflow coming out of the vents. This would have to be cleaned by a technician.
Most of the time, it is the charge which also means there is a leak in the refrigerant system somewhere and needs to be fixed. Hope this helps you out! Good luck.
Jun 19, 2012 | Ruud UAKA030 Air Conditioner
Model UAKA 030JAZ was working fine. Now, the compressor fan does not come on and neither does the compressor. I don't know how the contactor works but it is not engaging (the spring loaded contacts are...
Hello
You need to complete the 24 volt circut from the themostat to the transformer to get the contactor to pull in.
Check for voltage at the transformer,should be 120 v in 24 volts out.Also there may be a small reset button on the transformer.
Apr 18, 2011 | Ruud UAKA030 Air Conditioner
Ok I had the problem with ruud uaka-030jaz. I think i hit the wrong buttons when sent your solution so im not sure my response went to u. I checked the outside disconnect..says on the panel it does...
Very bad - the burned part signals that there has been an short somewhere. The fact that the burned part is black signals that the short has been massive so it's probably in the compressor itself which means that the repair will be costly. Call a pro home to give you a quote, the bill may end up higher than your aircon is worth.
Jul 20, 2010 | Heating & Cooling
What is the control contactor rating on Ruud AKA-030JAZ
Hello You need 24volt coil/ 40 amp /2pole contactor.
Jul 07, 2010 | Ruud UAKA030 Air Conditioner
I am trying to find a parts list for a RUUD UAKA-030JAZ air conditioning unit (specifically the compressor/condensor contactor).
RUUD will only sell there factory parts to certified contractors. My advice to you is to find a local HVAC parts distibutor that will sell you generaric parts which will work just as good as the factory parts.
Jun 23, 2010 | Ruud UAKA030 Air Conditioner
Ruud UAKA030 Air Conditioner Logo
873 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
