Question about Sewing Machines
The fabric is being ruined by the feeder under the fabric. It is not the needle.
  • 135 Answers
It could be different things, the tread may not be locked in the top tension, you may have treads all wrapped up around the bottom bobbin. Take out the bobbin and look, re-thread the entire machine.
Posted on Jun 24, 2010
The feeder isnt feeding the fabric through
The length has to be above zero. Insure the bobbin wind is off.
Aug 02, 2016 | Husqvarna Huskystar 207 Sewing Machine
How do iget the material feeder to come up, it won't feed material on its own
Are you lowering the presser foot? The lever is an up/down feature on the very back of the machine behind the needle.
Are the feed dogs (the little teeth under the fabric) set on "darning?" If so, the machine will not move the fabric under the needle. There is a knob or setting somewhere on your machine for this function.
http://quilting.about.com/od/quiltingglossaryf/g/feed_dogs.htm
You should get a user's manual, if one is available, search for:
Make + Model + the word "Manual"
or contact manufacturer support
or at least spend some time watching sewing machine videos on YouTube.
Apr 11, 2016 | Sewing Machines
My stitch regulator will not work. I have had it looked at 2x but still will not change from 2.5 higher or lower.
What Viking is it ? Have you cleaned between the feeders? If all is clean, try this test. Remove needle. Turn hand wheel so that feeders are up. Put fabric in machine. Lower presser foot. Make sure presser foot pressure is set at normal. Try pulling the fabric towards the front of the machine. It should be hard to pull. If it is easy to pull you need new feeders. They are worn down.
May 01, 2015 | Husqvarna Rose
What are the numbers on the color coded needles
Needles made for different fabrics - are soft needle have a low number (ex.silk fabrics) and a hard needle has a high number(ex.canvas)
Make a test so you don't ruin the fabric or break the needles
god Luck
Jun 24, 2014 | Necchi 4595 Mechanical Sewing Machine
Fabric not advancing
run you finger over the feed dogs under the foot - can us feel them above the surround? if not, you have placed your machine into free style sewing, and the feed dog does not advance the fabric in this mode. Look in your manual and see where the feed dog gets lowered/raised - raising it again should solve your problem.
Nov 23, 2013 | Janome Sewing Machines
Feeder dogs will not feed fabric at all.
it's possible that the feed dogs need a adjustment or they need to be
timed by a sewing machine repair technican
Dec 06, 2012 | Sewing Machines
Fabric quit feeding through
there called feed dogs & if they don't feed the fabric thur the machine need they need to be check to see whats wrong with them
Mar 07, 2012 | Singer 3116 Simple
Will it sew without the footfeed?
The feeder is what makes your fabric move towards the needle as you stitch. Without the feeder you will have to manually move the fabric forward - carefully - in order to sew. I recommend taking your machine in to have it repaired.
Nov 21, 2010 | Singer Sewing Machines
Needle stays in one place. Fabric does not feed
There is a latch under the the feeder lpate next to the bobbin lift it up to lift the feeder feet. wcbotha@yahoo.com
May 10, 2010 | Singer 7426 Mechanical Sewing Machine
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
